Old 09-28-2023, 08:53 AM   #15
bptuner
Drives: 2018 zl1
Originally Posted by CW3SF View Post
I’m one of the cars King has tuned. Add the HPFP, +30 injectors and JMS booster and you can make 740whp on e50 using the stock pullies. It is not true that you need to spin the Stage X port faster to make power, if you are using e85. Pulley’s on 93 will just add more heat.
This route isn’t cheap but it’s a winning formula.
Thanks for the advice. I may end up doing valve springs and retainers at some give some insurance when running higher RPM's, Katech oil pump is also on my mind. I may forgo the E for now and see if I like the power I get when tuned. I'm prepared to do a low side pump at this time, but not low/high/injectors.
bptuner is offline   Reply With Quote
Old 09-28-2023, 08:57 AM   #16
CW3SF
CW3SF's Avatar
Drives: 2019 Chevy Camaro ZL1 M6
Sounds like a good plan. The big advantage to doing the injectors and HPFP now is that the blower has to to come off to replace them, then it’s only about an hour job to replace both items. I did mine while I waited for Kong to do their magic.
CW3SF is offline   Reply With Quote
Old 09-28-2023, 05:13 PM   #17
bptuner
Drives: 2018 zl1
Order a barrel of E98 and just mix it with your pump fuel and keep it around E50. Should last you a year unless you put a lot of miles on the car.
Should I stay with stock heat range plugs, or down a step colder?
Old 09-28-2023, 08:01 PM   #18
ZLRob
Super Stock
ZLRob's Avatar
Drives: Chevrolet Camaro ZL1
If you cross over the 600 WHP threshold then you step up to heat range 7 plugs. If not, you stay stock.
758 HP/ 804 TQ
