Old 09-13-2023, 10:30 AM   #15
Nimair.ZL1
Drives: 2023 Chevy Camaro ZL1
Originally Posted by Megahurtz View Post
Oh damn I think I saw the video and the datalog from your car. Were you logging when it blew? My biz partner sent me a video and a datalog from a ZL1 that just popped in Texas.
Yup that was my car. I did log the car when it blew. I sent him the log
Nimair.ZL1 is offline   Reply With Quote
Old 09-13-2023, 12:20 PM   #16
ZLRob
Super Stock
ZLRob's Avatar
Drives: Chevrolet Camaro ZL1
Brother. I say this with respect, but let me try and zero in on the basis of this thread. You are willing to drop (most likely without a doubt) tens of thousands of dollars on a while new engine block and it's respective mating assemblies, but you are unwilling to spend a few hundred on inspecting current engine integrity which could potentially save you from spending those tens of thousands and keep you within the thousands for a potential rebuild of what may very well be a still intact engine block?
It's your money at the end of the day, I'm just trying to help you see the bigger picture here as you and I both know very well that the money you save if things are still okay can be used towards other larger and more fruitful projects.
758 HP/ 804 TQ
Old 09-13-2023, 01:05 PM   #17
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
Drives: 2023 SGM ZL1
Dannnggggg sorry to hear it was you man. The log didn't show anything troubling until it popped. I suspect the issue was mechanical vs the tune. You going to have Arash do the new build?
Old 09-13-2023, 01:32 PM   #18
Nimair.ZL1
Well actually the engine build is only if the current engine is bad. It will be inspected first to see what happened and how it happened and why it happened first. The we will see what's salvageable and what isn't. The built engine is there only if I can't reuse my current block
Old 09-13-2023, 01:48 PM   #19
2018ZL1
2018ZL1's Avatar
Drives: 2018 ZL1 A10 NFG 2019 COPO 350 SC
Wanting to get some opinions on the build.
L8T block (for future proofing)
400 Cubic inches
10.5:1 compression
Forged rotating assembly (callies crank and rods, diamond pistons)
Plan for the car is stock blower for now but going to a 2650 in the future
My new build consists of this;
-new lt8 iron block
custom diamond 10.5:1 pistons with AP total seal rings
-callies magnum 3.622 stroke crank(8ccw)(DUAL KEY WAY)
-c5r timing chain
-dual key the current ati hub
-callies ultra enforcer rods 6.125"
-ACL rod/main bearings
-Oil Squirter Plugs
-Mill heads .006
-ARP main studs
-LMP custom blower cam
240/258 118+4 LSA 365/360 LOBE LIFT
-johnson solid lifters
-COMETIC MLX head gaskets
Just now finally getting to drive it around, seems stout! I can tell you that L8T block weighs 200lbs more than the 6.2 aluminum block! Scales dont lie!
Have a track rental scheduled for October 20th so I will know how fast it really is!
2019 COPO #32
350 SC
8.25 167MPH
2018 ZL1-NFG-A10
388CI L8T
9.32 147MPH
2018ZL1 is offline   Reply With Quote
Old 09-13-2023, 02:01 PM   #20
SOCAL.M6.ZLE
Having FUN in the SUN...
SOCAL.M6.ZLE's Avatar
Drives: 2022 M6 ZL1 1LE
That sucks... interested to find out what happened. So perhaps we can learn from this... So sorry to hear this happened.
Old 09-13-2023, 02:09 PM   #21
2018ZL1
2018ZL1's Avatar
I am curious to see if it was the good ole thrust bearing that caused this! Was on mine but I had a few more mods than you...
2019 COPO #32
350 SC
8.25 167MPH
2018 ZL1-NFG-A10
388CI L8T
9.32 147MPH
Old 09-13-2023, 05:10 PM   #22
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
-new lt8 iron block
-c5r timing chain
-Oil Squirter Plugs
-Mill heads .006
-ARP main studs
Wow, you really wussed out on the cam….
LMAO! That’s pretty damn beefy!
Old 09-13-2023, 07:34 PM   #23
ZLRob
Super Stock
ZLRob's Avatar
Understood. I just wanted to make sure that that avenue was one you had considered already. Personally. It sounds like the block is just fine, but testing always tells you the final story.
758 HP/ 804 TQ
Old 09-14-2023, 07:42 AM   #24
Nimair.ZL1
Yes sir. For sure want to find out what happened first. Will keep this thread updated but should know by Monday. I think I either dropped an exhaust valve or spun a thrust bearing
Old 09-18-2023, 02:43 PM   #25
Nimair.ZL1
***********UPDATE**********
So took the engine out only to find a piece of the exhaust valve head in the exhaust port where the headers flange is.
Old 09-18-2023, 02:52 PM   #26
Z OH 6
Drives: 2024 CT5-V Blackwing
Sounds like an engine build issue since you swapped the cam
Old 09-18-2023, 02:57 PM   #27
Nimair.ZL1
Only thing in the heads that was changed was the springs, pushrods, and lifters. The head was un ported and the valves were factory
Old 09-18-2023, 03:20 PM   #28
Z OH 6
Correct but if the wrong length pushrods were used, it could have caused a valve to come in contact with the piston or were you saying that a piece of the actual head broke off? If so that would be Extremely rare and that would be a casting defect.
