#15 | |||
Moderator
![]() Quote:
#16 | |
![]() ![]() Drives: 2018 HBM ZLE Join Date: Aug 2017
#17 | |
Moderator
Everything is weighed on a commercial refrigerant scale. Extremely accurate. I weighed the OEM bar then the Cordes one back to back. You’ll see a little weight savings but it’s more for the room it gives you up front. Since I don’t have an intercooler it doesn’t matter lol.
#18 | |
![]() ![]() ![]() ![]() ![]() Drives: 2019 Camaro Z-28 Join Date: Jul 2010
taht
Also even the CORDES bar WILL be visible thru the grill. That's why they say they can powdercoat it at additional charge for you. I will verify that with Cordes also. If you have any concern over crash protection, the stock aluminum crash bar will absorb MORE energy that that single chromoly bar will. No doubt though that the chromoly bar is MUCH better than nothing.
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 |
#19 | ||
![]() Good stuff Quote:
#20 |
![]() ![]() Drives: '86 IROC-Z '18 ZL1 Join Date: Jul 2019
#21 |
![]() ![]() ![]() ![]() Drives: 2023 ZL1 Join Date: Dec 2022
Speaking of ProCharger... stock ZL1 engine with bolt on ProCharger and 2" Kooks Headers you get 225rwh??? (almost 15lbs boost)
https://youtu.be/s3zOiN1LYh0
Katech Track Day CAM 38%•BTR Dual Valve Springs•Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper/ATI SD w/10.32” +20%•10 Rib Belt•RFBG•FI IC Stage 2•THPSI Port w/875cc Inj•Katech Dual Fuel Pump•DSX Aux Pump•SW 2" Headers w/Legend NPP•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout &Bushings Kit•BMR Rear Suspension & 15" Conversion•DSS 1pc DS•RPM 6-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
#22 |
![]() Drives: 2021 ZLE, 2022 must GT, 2022 f250 Join Date: Apr 2023
I ordered one of those crash bars to try and increase some flow to my center coolers. It is supposed to arrive Friday. I’ll be installing in the coming weeks. I’m not sure what I’m going to do yet for a front tow hook mount as it’s required for almost any HPDE or TT sanctioning body.
#23 |
Drives: 2020 Camaro ZL1 Join Date: Oct 2020
I have seen where people have wrapped that front crash bar section with a type of carbon fiber wrap, i liked the look of it for the esthetics and it still keeps it there for any safety purposes. Just a thought.
#24 | |
Having FUN in the SUN...
![]() Drives: 2022 M6 ZL1 1LE Join Date: Jan 2022
Awesome, please share some photos when finished... I emailed Cordes, but they didnt have any installed photos.
2022 M6 ZLE: GMS Stage.III KONG X.PORT Package + DMS Lid + GMS Rear Bumper Belly Pan + GMS Hood Bracket + GMS Flex Fuel Package + MONSTER Triple S Clutch + XDI.50% Injectors + CLICK FOR BUILD LIST or www.GRIFFIN-MOTORSPORTS.com = 915rwhp 850rwtq + E60 + 15psi
#25 | |
#26 |
https://www.instagram.com/p/CwMMzqkt_AB/?img_index=1
https://www.instagram.com/p/CwMMzqkt_AB/?img_index=5 https://www.instagram.com/p/CwJaiFutumi/?img_index=1 https://www.instagram.com/p/CwJaiFutumi/?img_index=3 Everything fits great so far. the factory ducting, as it turns out, relies heavily on the stock crash bar. I had to fully duct in both aux coolers and main cooler stack. I couldn't find thicker than 3/16" plate locally so I doubled up when I made my tow hook mount. Its very study. flat towing probably would have been ok with a single piece but I winch in and out of an enclosed trailer so the double 3/16" is extra strong on an incline. the bar sits right behind the grille nicely. I had to trim a little in the center of the grille but not nearly as much as I had originally planned. I had to make in total 4 brackets to fasten some OEM ducting pieces as well as the trans cooler that also bolts directly to the factory crash bar. while I was in there I trimmed out the shroud to fully expose the trans cooler. factory blocks it off partially I assume to keep some heat in the trans in cold climate. |
#27 | |
![]() Drives: 2021 Camaro ZL1 Join Date: Mar 2023
2021 Camaro ZL1 Satin Steel Metallic
Rotofab CAI, Banks Idash, AEM X series wideband, CSP 2" headers, Jet hot 2500 ceramic coating, DSX Flex Fuel Sensor, DMS Fender Tank, Velossatech Big Mouth, JMS Fuel Booster, MPI Billet Lid, Jokerz race port, 2.30" upper, 107mm Soler TB, 160°F Billet DMS, Big Gulp, LPE Big Bore HPFP, XDI +30, ECM & TCM tuned by Elite Tuned, BMR Cradle Lockouts, Atturo 315 AZ850DR |
#28 |
Petro-sexual
That bar could also add stiffness for chassis flex, too.
