#15 |
NYTMARE23
Drives: Black 2023 ZL1 A10 Join Date: Oct 2022
If you're not blowing it up, then you're not trying hard enough..right Greg??!!
2023 A10 ZL1 "NYTMARE"
#16 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro ZL1 Coupe Join Date: May 2016
I guess so!
#17 |
![]() ![]() ![]() ![]() Drives: 2018 Hyper Blue ZL1 1LE Join Date: Dec 2018
When a high performance manual trans fails can/does this kind of thing ever happen, meaning the catastrophic damage where it explodes and catches fire sending shrapnel in in all directions?
I don't think I've seen that, or this with an automatic or dual-clutch either. This sort of incident on a dyno has always been motor failure as far as I recall... I've seen a lot of those videos. |
#18 | |
![]() Drives: 6th Gen LT1 Join Date: Jun 2023
It is more rare to have a failure like that but it can still happen. Autos in case of shifting failure can engage wrong gears or several at the same time and lock up. In a manual that's way harder to do. |
#19 | |
#20 | ||
#21 | |
![]() ![]() ![]() Drives: 2018 ZL1 Camaro 6M Red Hot Join Date: Aug 2013
I have heard of broken shift forks and gears breaking, but nothing this serious. Has someone seen a tremec blow up like this? If so, send me a link. Just curious...
People are a lot like slinky's: not very helpful most of the time, but they bring a smile to your face when pushed down the stairs...
#22 | |
![]() Drives: 6th gen Join Date: May 2020
#23 | |
Like 5th to 2nd you can lock up the rear tires and spin out. I had pressure plates rivets breaking while shifting at 6k rpm. Did 4 clutches until I got a race clutch with no dampening at all to fix the issue. They both have pros and cons. Autos seems to explode under weird shifting scenarios. Burnouts and dynos. Both scenarios trick the computer at some point. |
#24 | |
#25 |
Long hauler
Hopefully, that's why they added Line Lock into 2019+ (gonna be a nice send-off for these tires when they're low enough
2016 1LT v6 - Totaled Happiness: Infinite |
#26 |
Drives: Nickey Super Camaro Join Date: Nov 2008
Glad to see that no one was hurt. Things could have been real bad.
While I don't have any on video, yes Manual Transmissions can come apart / explode as well. The gear oil is much less likely to catch on fire than the ATF. I don't believe anyone should have worries about road racing close to stock ZL1s. We have experienced two cracked transmission cases in road race applications (fast tracks) one Tremec and one 10L90. This was due to aftermarket driveshaft harmonics. |
#27 | |
#28 |
![]() ![]() Drives: 2017 ZL1 Join Date: Jan 2017
Line lock is in all ZL1 2017+
