#15 |
![]() ![]() ![]() Drives: 2023 ZL1 - All Bolt On's Join Date: Dec 2022
Can you report back how much E your able to run once you get your tune done? Do you use HPTuners and will do your own data logging? If so, it will show the amount alcohol your reading. I'm only curious because I'm getting ready to add my DSX Flex Fuel kit and a JMS FuelMAX Pump Booster to my ZL1. Thanks
#16 | ||
Super Stock
Drives: Chevrolet Camaro ZL1 Join Date: May 2022
2017 Red Hot ZL1 A10 - Apex ARC-8's, 305/ 325 PS4's, DSX 9.06 12% lower, Griptec 2.5 upper, NGK HR7 Ruthenium plugs, Nostrum 22+ injectors, XDI Goliath HPFP, Katech dual in tank low side pump, Katech oil pump, LME tensioner, DOD delete, LT1 big fuel cam, Jokerz ported blower, MPI lid, GMS hood extractor bracket, Soler ported 87mm (91mm eff) TB, Granatelli SS plug wires, Cordes LTR reservoir, DMS T-stat housing, 186* LS3 T-stat, Black Widow Angry Housewife/ Corsa NPP mufflers, Borla X pipe, BMR engine mounts, Banks iDash, Lithium Battery, AEM X- Series, HP Tuners, E85, 16.5 psi
834 HP/ 840 TQ |
#17 | |
Super Stock
834 HP/ 840 TQ |
#18 | |
fo'shizZL1
Drives: 2017 ZL1 Join Date: Aug 2017
Mods being installed- oil pump, cam, ported heads, dual in-tank, Goliath and XDI, corn, etc., etc. |
#19 |
Super Stock
I found a better photo.
Okay, so apparently the LT4 and 5 share the same cylinder heads, no questions there. Where they differ, however, is that TVS2650 blower. Within the blower, there is machining within the ports to be able to accept MPI injectors and there are provisions built into the blower itself so it can accept a pair of fuel rails and their respective ports for the injectors. I suppose this is where those aftermarket "spacers" that are built for ours come into play. There may be extra wiring integrated into the factory wiring harness as well to be able to run the Bosch MPI injectors that come factory on the LT5's as well, but from the looks of it, we (LT4 cars) already have native software and hardware built into our FPCM's to be able to run multi port injection ON TOP OF DI from the getgo.
834 HP/ 840 TQ |
#20 |
fo'shizZL1
I believe Steck is working on a neat solution that uses the factory ECM to control port injection.
#21 |
Super Stock
That would be flippin' cool!
834 HP/ 840 TQ |
