Old 06-25-2023, 08:46 PM   #15
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Originally Posted by synolimit View Post
no unless you tune for it and even if you tune for it, the tuner may get a degree out of it or maybe not netting is zero to maybe a HP or 2.
You don’t have to tune for 94. That’s so close to 93 and it will help prevent knock retard in high heat or high load conditions.
Originally Posted by Boost Creep View Post
There was a Sunoco station that had 92 pure gasoline, no ethanol last summer.
My question would be, is 92 pure gasoline better than 93-94 with the ethanol mixed in?
I’d take the higher octane with ethanol every day of the week.
Old 06-26-2023, 09:54 AM   #16
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Josh is spot on. Being 93 octane is bare minimum octane for the LT1 engine, I would put 94 in it every chance I could. But the best solution would be to install a flex sensor and run E50 or higher. These engines live on the knock sensors and actually need a little timing pulled to run 93 octane with no knock in a lot of weather conditions.
Old 06-26-2023, 10:01 AM   #17
JSH
JSH's Avatar
Drives: '20 ZLE
Technically, 91 octane is the bare minimum, but Colorado and California might be only states with 91 as their highest octane
2020 ZL1LE A10.
LME LT4 390 short block, CID Heads, Kong E2650, FBO.
15" conversion, Nitto 555Rii or MT ET Street R or Toyo Proxes RR.
100 octane: 1045hp/1055tq.
100 octane + Alky MAF Meth (1) 10+:
Old 06-27-2023, 10:18 AM   #18
KingLT1
KingLT1's Avatar
Point being 93 octane is the absolute bare minimum octane you should run and even then, you will still likely get knock retard in a lot of weather conditions with the LT1. 91 octane will be even worse. I wasn't saying anything in regards octane minimums from state to state to be considered "premium" fuel.
Old 06-27-2023, 12:12 PM   #19
JSH
JSH's Avatar
Drives: '20 ZLE
... you will still likely get knock retard in a lot of weather conditions with the LT1.
I can't speak to the LT1, but I don't recall logging any retard when my car was stock or on HPE's 850. I'll look.
2020 ZL1LE A10.
Old 06-27-2023, 01:33 PM   #20
FH212
FH212's Avatar
Drives: 2015 Camaro Z/28
And New Mexico. We only have 91.
2015 Camaro Z/28 - Red Hot
1978 Trans Am Y88 Special Edition 400/4 speed
2001 Mecham Trans Am #3 - 7.0L LS1
FH212 is offline   Reply With Quote
Old 06-27-2023, 06:14 PM   #21
Geese1
Geese1's Avatar
Drives: 2022 2SS 1LE - 2023 Mazda3 Turbo
Quite a bit of the country only has 91 octane as the highest normal fuel grade. I just took a trip out to Utah the other week, and once I hit about Kansas, the highest I ever came across was 91. Some stations I came across in the midwest only had 87 octane, with no other choices. I passed those by, but I could only run 91 until I got closer to home on the return trip back.
2022 Camaro 2SS 1LE - manual - Rapid Blue
*Black Wheel Lug Nuts and Locks Package
*Knee Pads, Black Sueded
4/15/22 - #1100
4/19/22 - #2000
4/22/22 - #3000
4/26/22 - #3000 - TPW 5/23
5/12/22 - #3400 - TPW 5/23
6/18/22 - #4300
7/25/22 - #6000 - Took delivery
5/28/23 - hit 1,500 miles - break-in officially over!
Geese1 is offline   Reply With Quote
Old 06-27-2023, 07:41 PM   #22
6spdhyperblue
Drives: 2SS 1LE
Luckily its a beast with that 19 gallon tank
Old 06-27-2023, 10:33 PM   #23
carguy55
carguy55's Avatar
Drives: 2018 1SS 1LE
I had to run 1/2 tank of 93 and 1/2 tank of 100 on track . Made no difference. Have to be tuned for it.
Mods: MSD, Headers, 95mm TB, high flow cats, full 3" exhaust, SPL, MCS 2-way remotes, sway bars, rear diff lock outs, Sparco racing seats, 6 point harness, CMS roll bar, Nine lives wing, 6" splitter, ACS canards.
www.youtube.com/@Racer_Mike87
Old 06-28-2023, 09:19 AM   #24
JSH
JSH's Avatar
Drives: '20 ZLE
Yea, you could definitely add some advance/fuel to your 97 octane mixture
2020 ZL1LE A10.
Old 06-28-2023, 10:41 AM   #25
synolimit
Drives: 22 ZL1 1LE A10
i didnt say you had to. i said the tuner "might" get a degree more of timing if he maxed out on 93 but maybe not netting in zero to maybe a HP or 2.
synolimit is offline   Reply With Quote
