Old 05-13-2023, 06:29 PM   #15
65ffr
65ffr's Avatar
Drives: '18 ram 1500
Not sure about previous years but the '23's have DOT 4 from the factory
2023 ZL1 Radiant Red 6 spd, pdr, carbon fiber hood
1100 10/28/22
2000 12/6/22
3400 12/17/22
TPW 1/9/23
delivered 2/7/23
65ffr is offline   Reply With Quote
Old 05-13-2023, 06:31 PM   #16
Vigilante375
Drives: 2018 Camaro ZL1
That a fact? I haven't read anything stating this.
Old 05-13-2023, 09:11 PM   #17
65ffr
65ffr's Avatar
Can't figure out how to copy/paste but page 249 from the 2023 owners manual.
"The clutch/brake master cylinder reservoir is filled with GM approved DOT 4 brake fluid as indicated on the reservoir cap"
1100 10/28/22
2000 12/6/22
3400 12/17/22
TPW 1/9/23
delivered 2/7/23
Old 05-14-2023, 06:44 AM   #18
Vigilante375
If this is true, it took GM over 5 years to finally start putting DOT4 in the car. Just like them finally relocating the fuel harness 4 or 5 years after the production of the 6th gen.
Old 05-14-2023, 10:24 AM   #19
Fstlane
Drives: 2019 Summit White ZL1
Are the seals in the calipers rated for DOT4? Just asking because I roosted the brake system in my 280 Z years ago doing that. Thought I would upgrade and ended up killing the entire brake system...and to top it off I took awhile so I went from brakes working to suddenly not brake at all.....what a surprise! Needless to say I would do some research before dumping in DOT4
Fstlane is offline   Reply With Quote
Old 05-14-2023, 10:47 AM   #20
JamesNoBrakes
JamesNoBrakes's Avatar
Drives: 2SS 1LE
DOT 3,4 and 5.1 are all chemically compatible. DOT 5 is not.
2018 2SS 1LE
2023 Colorado ZR2
2022 Stinger GT-line AWD
JamesNoBrakes is offline   Reply With Quote
Old 05-14-2023, 10:59 AM   #21
Vigilante375
Yes. In the manual and track prep guide it states to use DOT 4 for road course usage. It's been there since 2017 when the ZL1 came out.
Like many other ZL1 owners on here, I've used DOT 4 in my 2018 ZL1 since 2018.
Old 05-14-2023, 01:05 PM   #22
Fstlane
Cool good to know. Thanks for sharing!
Old 04-19-2025, 09:16 AM   #23
Transformerrk
Transformerrk's Avatar
Drives: 2023 ZL1 1LE, 2010 SS Transformer
Thank you everyone. I have been using the various track modes, depending on the conditions and my mood, but always in track mode.
Question: does anyone ever use sport mode? only reason why I ask is sport mode uses the entire RPM range/goes up and down, and track seems to keep it near redline the entire session. Is this fine for the engine to keep near redline the entire time? I know it's kinda late after two years on track to ask lol but just wondering? thanks
Transformerrk is offline   Reply With Quote
Old 04-19-2025, 10:27 AM   #24
SpeZ
SpeZ's Avatar
Drives: 2019 ZL1 "1LE" | 16 SS | 2017 F30
I only used track mode for track and PTM in "Dry".
The performance mode keeps the revs high to faster accelerate out of corners.
Only issues might be hot engine oil temps and a little higher trans fluid temps.
But with mine, I can't really accelerate fast out of corners, steering angle combined with throttle cuts noticeable the power.
Did you notice the same? I probably have to reprogram my traction control with the torque.
I will be tracking tomorrow.
Edit: 04-21-2025
Accelerating out of corners were alot better, I adjusted Traction control with hptuners. It was not aligned anymore caused by mods.
Callaway SC750 ZL1, DIY 1LE with added OEM 1LE Wheels, DSSV Suspension and 1LE Aero, FEA front control arms, DIY oil cooler, CWA 150 pump, bigger intercooler, Phenolic blower spacer, 82°C thermostat, BMR lockout kit, CTSV Brake Air Deflectors, Smooth idle cam, LS7 lifters, Bronze trunnion bushings. Tuned by JRE
SpeZ is offline   Reply With Quote
Old 04-26-2025, 09:57 PM   #25
Transformerrk
Glad you had a good time and going from an SS to a ZL1 1LE, there is soooo much more left in the car. Just keep going and push little by little where you can.
People talk bad about how the stock Goodyears are garbage but those people are the ones who only car about straight line speed. The 3 and 3r are very sticky when warmed up and at the correct pressure. They give you all their grip from new to when they cord.
By the way, did you change out the stock brake fluid to DOT 4? If you haven't then you need to do so before then next event.
Thanks, I just got 4 new SC3s, 15-W50, and DOT4 brake fluid. Diff and Tranny fluid still good. Inspected the entire car, ready to go!
Old 04-26-2025, 10:01 PM   #26
Transformerrk
Edit: 04-21-2025
Track/dry cuts some power in corners and uses a lot of traction control, the higher settings of track cut more controls and give more power but can get scketchy. Track/race is full power with no controls, all driver skill and scary. I like track/dry or track/sport 1.
Old 04-27-2025, 11:18 AM   #27
65ffr
65ffr's Avatar
Not quite. Track/race does not have stability control, but has traction control (which can limit power)
1100 10/28/22
2000 12/6/22
3400 12/17/22
TPW 1/9/23
delivered 2/7/23
Old 04-30-2025, 04:37 PM   #28
Blackrat
Drives: 2021 ZLE & 1972 Camaro
Edit: 04-21-2025
I've done two events, first one was rainy during the first half and dry in during the latter half. I flipped from Rain to Sport 1 and was really happy with the car all around. I recently did an event at a track I had only been to once before and which also had much less room for error. With that in mind I kept it in DRY for every session. The car felt really off to me and I was not happy with the balance or performance of the car. Checking my PDR after I saw the nannies light on over half of each session lol. The description from the other threads discussing PTM (about using dry if you're learning the track or for newbies) is apt, but it steps in quite a bit to limit rotation and is way too conservative on power application once you have your lines down.
I have read that the step up from sport 1 to sport 2 is quite dramatic though. I remember video from a nice c7 that spun out entering the track and slammed into the wall before flipping on its roof. Consensus was that if the guy had left it in sport 1 like he had prior that wouldn't have happened.
Blackrat is offline   Reply With Quote
