#15 |
![]() Drives: 2019 ZL1 Camaro Join Date: Oct 2016
Beautiful car!
Welcome to the club. How does it compare to the Grand Sport? Enjoy! Tyrolblue67 |
#16 | |
2. You can set all 3 positions with any key, and then recall them manually. However, the auto memory recall feature (that adjusts the seat without you doing anything when you hit the start button) is understandably bound to a key fob, the car has no way of knowing who's driving if they use the same fob. I have the comfort options set up so the driver seat automatically moves to the exit position on opening the door, then it automatically moves to the #1 or #2 saved position depending on the fob used when driving it the next time. I use fob #1 and my wife has fob #2. When both fobs are in the car, it defaults to the last one used. As a result, I almost never have to adjust the seat or the side mirrors, it's always perfect for the driver. 3. Traditionally, there is no such thing as "radio off" on GM cars, at least not the ones we've had, including the Camaro. If the infotainment system is on, you hear music from the currently selected source, be it AM/FM, XM, media, USB etc. The only way you can use the infotainment without music is indeed muting the audio or manually setting the volume to 0.
#17 |
![]() ![]() ![]() ![]() ![]() Drives: 19' ZL1 A10, w/pdr Join Date: Sep 2014
Congrats welcome, nice color it grows on me.
#18 |
Not sure if this is what you mean, but often I'll travel with my family and we don't turn on any music. But I want to be able to hear the audio alerts from my phone or Android GPS program (Waze). I turn on bluetooth, pause the music, and then I can still hear the audio alerts from Waze. I haven't figured out any better way to do it that doesn't require just a little input on my end.
Soler DLX Bluetooth Throttle Controller / OFFKAT Smoked LED Side Marker Lights / Blue SS emblems on front & rear / Wildhammer Rear Dark Reflectors / Trim Illusion Gloss Black Door Handle Covers / eBay Black Fuel Door / Screaming Chicken Fender Hash Marks / Color-Matched G2 Caliper Paint CT Sounds Tropo 10" Sub / Down4Sound MM1000 Mini Maxx amp / JL Audio LoC-22 line output converter / Sub Thump Plug N Play T-Harness With ANC Defeat Harness Kit My Camaro Journal |
#19 |
![]() Drives: 2017 ZL1 Vert M6 Join Date: Feb 2019
Welcome and GREAT color!
#20 |
![]() Drives: 2022 Chevrolet Camaro ZL1 M6 Join Date: Aug 2021
beautiful car. enjoy yourself
#21 |
![]() Drives: 2022 ZL1 Join Date: Dec 2021
Congratulations
#22 | |
![]() Drives: 23 ZL1 M6 Join Date: Mar 2023
Overall feels and looks great. The recardo seats are awesome |
#23 | |
3. Press and release SET; a beep will sound. 4. Immediately upon releasing SET, press and hold memory button 1 or 2 matching the current Driver’s remote key number until two beeps sound. If too much time passes between releasing SET and pressing 1 or 2, the two beeps will not sound indicating memory position were not saved. Repeat Steps 3 and 4 to try again. |
#24 | |
One can still recall either position #1 or #2 manually regardless of the fob. Another thing you might have missed, unlike with earlier GM vehicles, in the Camaro one has to hold the memory button down until the seat stops moving when performing a manual recall (how lame, but that's their definition of "safety" for you/us). When you say memory seat #2 "does not work", what do you do and what is not happening that you expect?
#25 |
#26 | |
If this is what happens, then that's indeed a failure, maybe button #2 is dead, the module could be faulty, a wire or terminal connection could be open... if this is a CPO unit, have the dealer fix it under warranty
#27 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2023 Black ZL1 Auto Join Date: Oct 2009
Pull the exhaust valve fuse in the engine fuse box. I believe it’s no 51. It won’t make the exhaust louder but you’ll hear it more under lighter acceleration since you’re not waiting for the ECM to open the valves.
#28 |
Yes i will be installing Mild2wild switch which i had in my corvette too, great mod
23 ZL1 Coupe /M6/Rapid Blue
