Old 04-28-2023, 07:11 AM   #15
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
I didn't even use a pump. I used one of the caps, from another bottle of fluid, that has the funky graduated end, where you can trim it to a certain OD, and a small barb to slip a piece of hose over, and just squeezed the fluid out of the bottles. It took having 3-bottles to do (I had a partial left-over from the first flush/replacement around 1000-miles), but it did the job. It took longer, but I just started at everything underneath, so I didn't mind much. Fluid pumps are such a PITA to use. I admit their ultimate utility, but unless you're a mechanic, I'm not sure it's worth the mess, clean-up, etc. JMHO.
'20 ZL1 Black "Fury"
Old 05-02-2023, 08:44 AM   #16
FRANK121
FRANK121's Avatar
Drives: 2022 Camaro ZL1
Correct Fluid?
I have the 10-4034 coming but noticed it does not have GL-5 on the label is this the correct gear oil?
https://www.amazon.com/ACDelco-10-40...xpY2s9dHJ1ZQ==
2022 Black ZL1
RotoFab CAI, AWE Touring Edition Cat Back Exhaust.
665 Crank hp. est. and 660 Crank ft. lbs. est.
Never been Dynoed
FRANK121 is offline   Reply With Quote
Old 05-02-2023, 08:51 AM   #17
FarmerFran
FarmerFran's Avatar
Originally Posted by Rapid_blue_zl1_22 View Post
For those using ramps to change the diff fluid, the diff is supposed to be level to fill it properly. If the diff is slanted the fill port will be lower causing the fluid level to be slightly lower once the car is level again. It probably won't matter much, but just an FYI.
Very very true. Mine was totally level OCD. The above pic looks like it is level-ish due to the slant of the driveway
<Insert Cars You Own Here>
Old 05-02-2023, 10:15 AM   #18
SSEssence
Instagram: Sangstah
Drives: 2019 Camaro 1LE
Yes, this is the correct fluid.
SSEssence is offline   Reply With Quote
Old 05-04-2023, 01:48 AM   #19
1sickzl1
1sickzl1's Avatar
Drives: 2022 ZL1 M6
Use the syringe, it's so fast. They have them on Amazon for $11
2022 Black ZL1 M6
RF intake, Soler TB & TC, ADM v2 reservoir, AWE Touring non-resonated catback exhaust.
535 whp, 537 tq. SAE Smoothing: 5. DynoJet.
No tune. 91 octane.
1sickzl1 is offline   Reply With Quote
Old 05-04-2023, 08:33 PM   #20
triggerjerk
Drives: 2023 Camaro ZL1
This should work.
triggerjerk is offline   Reply With Quote
Old 05-04-2023, 09:38 PM   #21
Badmojo
aka BeastZL1
Badmojo's Avatar
I used one the last time I did it.
It worked, but the bottle top pumps make less of a mess.
Originally Posted by Rock-It Man View Post
Has anyone used a syringe type pump? It doesn't have to fit a bottle top.
For example:
https://www.amazon.com/Thorstone-Aut...2s9dHJ1ZQ&th=1
2019 Camaro ZL1 1LE
Racing for ALS Youtube Link
Old 05-05-2023, 03:47 AM   #22
65ffr
65ffr's Avatar
Drives: '18 ram 1500
I just ordered the Slipper Pete fluid pump for wide mouth bottles, pumps 30cc per stroke, can empty the quart bottle in 32 pumps.
2023 ZL1 Radiant Red 6 spd, pdr, carbon fiber hood
1100 10/28/22
2000 12/6/22
3400 12/17/22
TPW 1/9/23
delivered 2/7/23
65ffr is offline   Reply With Quote
Old 05-05-2023, 10:19 AM   #23
302crossram
302crossram's Avatar
Drives: 2023 Sharkskin 2SS
buy a qt of Valvoline flex fill, empty it and use that to fill the the diff with the ac Delco oil
works great
