Old 04-25-2023, 08:12 AM   #15
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
Higher tire pressure helps but if you let the car sit for two weeks or more without driving it, you can get some mild flat spots that should go away after driving for a few miles and getting the tires up to normal operating temp.
Yes to this. I'm assuming this is the OP's issue.
Mods being installed-
Old 04-25-2023, 09:01 AM   #16
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
Yes mine bounce around too until they get some heat in them and then level out.
Old 04-26-2023, 02:04 PM   #17
2023_ZL1-AUTO
2023_ZL1-AUTO's Avatar
Drives: 2023 ZL1
So, yesterday after work the temp was 61°. I checked tires pressure again, lowered them to 32lbs for all (4). Hit the same stretch of 315N and took the same exit as I did this past Saturday. Good news, everything felt normal with no weird tire/road feel.
2023_ZL1-AUTO is online now   Reply With Quote
Old 04-26-2023, 06:31 PM   #18
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Case closed. Good deal.
