Old 04-18-2023, 10:36 AM   #15
JSH
JSH's Avatar
Drives: '20 ZLE
Originally Posted by Nimair.ZL1 View Post
So results are in!! On a cold pull it made 707RWHP with the 9.6 lower pulley and stock upper! Beyond satisfied!! Blower however is a restriction. Need to get it ported
P/P heads would be my recommendation.
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 04-18-2023, 12:33 PM   #16
Nimair.ZL1
Drives: 2023 Chevy Camaro ZL1
That is on the list to do. For now I need more cooling modifications so thinking about heat exchangers etc.
Nimair.ZL1 is offline   Reply With Quote
Old 04-18-2023, 01:07 PM   #17
JSH
JSH's Avatar
Drives: '20 ZLE
Yea, I did WeaponX oversized center cooler with the HPE850 pkg. in 2020. Coating the headers is up next.
2020 ZL1LE A10.
Old 04-18-2023, 01:30 PM   #18
Nimair.ZL1
Heard Weapon X now is not a good dealer. From what I've heard people that paid for parts have not received them over a year later.
Old 04-18-2023, 03:12 PM   #19
JSH
JSH's Avatar
Drives: '20 ZLE
I've never had a problem.
2020 ZL1LE A10.
Old 04-18-2023, 04:04 PM   #20
Z OH 6
Drives: 2024 CT5-V Blackwing
Sounds about right, mine made 697whp on 93 octane with a 9.45 lower and stock upper through high flow cats with stock cam. My blower is ported though, standard Kong port, not the X port. I do have additional cooling though, heat exchangers upgraded and a Cordes aux tank. Given there's some dyno variation, I would expect your combo to make 20-30whp or so more than mine. I agree I think you need more cooling and ported blower, then you could reduce the pulley size some and possibly run an E blend depending on your chosen pulley.
My next step down the road is to probably upgrade to the Kong X Port, reduce the pulley size, add a stage 1 mild cam and any other fuel upgrades to run an E blend.
Old 04-18-2023, 10:08 PM   #21
Nimair.ZL1
Yes sir. 707rwhp was also SAE. With the ported blower I should be 730-760rwhp with a cold pull in my opinion which is where you would be with a cam and all I believe
Old 04-19-2023, 06:12 AM   #22
Z OH 6
Yea, sounds right. You're already above the limits of street tire traction.
Old 04-19-2023, 07:35 AM   #23
Smokin19
Drives: 19' ZL1 A10, w/pdr
The tuner and equipment used can make a difference in the final numbers. Add to that temps at time of tune and a host of other variables. My tune on the Mustang dyno would show 6-7 % difference on a Dyna tune equipment as an example. This is why a base tune before a build is the only way to see what increase you achieve after using the same equipment.
Smokin19 is offline   Reply With Quote
Old 04-19-2023, 08:03 AM   #24
Nimair.ZL1
I like the drama lol
