#15 |
NYTMARE23
Drives: Black 2023 ZL1 A10 Join Date: Oct 2022
So what I'm gathering is AWE Touring is the best for Axle-Back WITH the NPP Valves??? Or is there another system better that utilizes the NPP still??
. I would like a system that I can still use the Valves with.
2023 A10 ZL1 "NYTMARE"
#16 | |
![]() ![]() ![]() ![]() Drives: 2023 ZL1 Join Date: Dec 2022
https://www.youtube.com/shorts/bSfzZKB-HnY |
#17 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2024 CT5-V Blackwing Join Date: Sep 2020
Quite a few choices that still retain the NPP valves, none sound like AWE.
#18 | |
NYTMARE23
Then I contacted Borla about the Type S axle back with black tips and they emailed me back and said that particular system is only available as a Cat-Back. ![]()
#19 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro ZL1 Coupe Join Date: May 2016
Stainless Works has a cat back system that keeps the NPP valves and a axle back too.
#20 |
NYTMARE23
Thank you!
#21 |
![]() Drives: 2018 Zl1 Camaro Join Date: Feb 2018
I run Stainless Works headers, Gesi2 UHO HP Cats, Corsa X pipe to Borla Atak NPPs axle backs and its loud with zero drone.
Big Gulp|NW103|SW Headers|UHO CATS|XPipe|Borla Atak|MM CC|Kong Ported|NSX|ATI Damper|DSX 9.45 Lower|ZPE 2.5 Upper|DM Tensioner|FW Green Belt/BTR Gen V LT4 Cam w/32% lobe/BTR VVT Lockout/Pratt & Miller Chain/BTR Pushrods,Valve Springs, Retainers, Hydraulic Lifters & Guide Plate, Trunnion Roller|Katech Valley|KaTech Valve Covers|MSD Coils|DSX E Sensor & Aux Pump|ICT Water Pump|Katech Oil Pump|Cordes & Mishimoto Expansion Tanks|P3 Gauge|LC-2 Wideband Sensor|KaTech Wires|DynoJet Tuned
#22 | |
![]() Drives: 2023 ZL1 Join Date: Jan 2023
#23 | |
NYTMARE23
#24 | |
#25 |
![]() Drives: 2019 ZL1 Crush Join Date: Jan 2019
AFE....
2019 Crush A10
E-Force 2650 670WHP 615WTQ All besides the 2650 is bone stock down to the air filter. |
#26 | |
#27 | |
NYTMARE23
#28 |
![]() Drives: ZLE/DEMON/GLADIATOR/GSXR1000R/ZX10R Join Date: Aug 2022
I like the Corsa NPP axle back.
Looks and sounds incredible.
2018 Dodge Demon #1399 2020 Jeep Gladiator Rubicon 6 speed manual 2023 ZL1 1LE 6 speed manual ************************* 2018 Suzuki GSXR 1000R 2021 Kawasaki ZX10R |
