#15 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: Hyper Blue 2016 2SS 6M Join Date: Sep 2017
Baby Blue
#16 |
![]() Drives: 2022 Camaro 2SS A10 Join Date: Jul 2022
Josh- thanks for the tip on the pierburg coolant pump. The shop likes that better than the bosch pump so I will order one myself. How about the wiring harness? Did you get the unterminated harness or the one for the CTS-V /ZR1 Corvette? to work with the current wiring- I think the current harness is 3 wire and looks like the pierburg coolant pump is 4 wire maybe?
2022 Camaro 2SS/ Whipple 3.0 / 2"Headers/ PRC LTX Heads/ Forged Internals/LT4 fueling/ DSX Aux/
DSX Flex Fuel/ Meth Injection/ Katech 112 TB/ RotoFab Big Gulp/ Corsa NPP/ Various exterior mods Last edited by adamjwilson; 03-21-2023 at 04:12 AM. |
#17 | |
Moderator
#18 | |
Moderator
#19 | |
![]() ![]() Drives: 2015 Camaro ZL1 Join Date: Oct 2020
https://katechengines.com/i-30498203...ction-kit.html |
#20 | |
I ordered the Pierburg pump from DMS, and they suggested the SC pump kit for the ZL1 due to the harness (Part#LTCWA150KIT) and not the kit with the unterminated harness due to the ZL1 harness is more suitable for our use...blah blah blah. Anyways, will still need to do some wiring for it to work on existing harness to Bosch pump (or replace harness). We will see when we dig into in a couple of days.... according to your chart, that Bosch pump is JUNK!!! (spend all that money on the Whipple and they include a cheap pump...go figure )
DSX Flex Fuel/ Meth Injection/ Katech 112 TB/ RotoFab Big Gulp/ Corsa NPP/ Various exterior mods |
#21 | |
Moderator
#22 |
Moderator
I mentioned it briefly before but the 3.0 blower pulley is apples-to-oranges vs the 2.9 ones. The 2.9 used a 4-bolt pulley and small diameter jack shaft opening, the new 3.0 uses a thicker shaft and 5-bolt pulley. I have virtually every 2.9 Griptec pulley known to man, so if anyone needs one let’s talk.
![]() In the meantime, the 3.75” pulley that Whipple shipped with the blower doesn’t work at my level, so I just put in a call to Griptec and have a new one coming that should fit the 3.0.
#23 |
A few 'CONS' along the way with the Whipple 3.0 so far:
1. Whipple's Customer Service is Horrible (Dealer or Consumer). Even the dealers can't pick up the phone and get answers, as Whipple wants everything via email or talk to their sales rep. Luckily I have an inside contact that is somewhat responsive to my questions... 2. Bosch Coolant Pump is JUNK... spend $8k on a supercharger and Whipple provides a replacement of the Varimax to Bosch pump which is well sh**... comparing the Bosch pump to the Pierburg Coolant Pump is night and day... run time will tell if the Pierburg pump is the real deal. Thanks to Josh on the comparison chart- (Note: even the place I bought the Pierburg pump from laughed at me when I told him that I had a bosch pump that failed- that should tell you something.) Whipple wanted the dealer to BUY another Bosch pump that should be covered under warranty because it failed within 5 minutes of use? WTH??? speechless 3. Whipple should provide more options to buy on the lower pulley (and upper for that matter)... luckily the aftermarket has taken up this slack. Overall, pleased so far with the build but more to come I am sure.
#24 | |
Moderator
![]() 2. The Varimax/Bosch units are similar to the OEM ZL1 units. They’re ok for people running 6-10 psi but if you’re going for big power, then yeah, they’re not going to work out well. 3. Whipple does offer pulleys at last check (7”, 8”, 9” on lower) but rather just hit up TooHighPSI for the lower and Griptec for the upper anyway.
#25 |
2. Whipple asking a dealer to BUY another Bosch pump after the initial one fails is crazy and just bad business. Not much faith in the bosch pump regardless of the PSI I may be running cause I gotta remove the front clip to replace if it fails!
3. The offerings by Whipple on the upper pulley goes to 15PSI and ends... (I won't be running that high at this point but luckily the aftermarket has taken up the slack on both upper and lower offerings)
#26 |
Not being biased here but hasn't Whipple had a bad reputation in the past for customer service? I don't know for sure but just with the complaints I've heard on this forum. Not saying that others are better but haven't heard the complaints on others as much as Whipple. I hope they start doing better since it appears they have a good product to offer in the 3.0.
#27 | |
![]() They have always relied on their name for business IMO (been around since 1987 or so), but others (Procharger comes to mind here) are not much better on the consumer side/assistance.
#28 |
Moderator
So it looks like we have more differences between the two Whipple blowers… the TB mounting flange. At first glance it looks bigger than the 2.9 flange (even though both blowers are 112mm inlet holes from the factory), but after mocking up my Katech 112mm TB, it’s not going to fit without an adapter of some kind. I’ll put in a PM to Katech_Mike and see what he says…
