Old 03-13-2023, 07:31 PM   #15
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
Originally Posted by Drnick View Post
Twin disc! Well that explains why I feel a difference
Between all my other car’s clutch engagement and
The ZL1.
For what it's worth, my last 5th gen ZL1, both with a stock dual disk and an aftermarket triple disk, felt like any other clutch.
Mods being installed-
Old 03-13-2023, 08:11 PM   #16
L78toLT1
L78toLT1's Avatar
Originally Posted by Katech_Zach View Post
The factory LT4 and LT5 clutches are great, I would just get a new OEM clutch. They are good for nearly 900rwhp without any issues.
I wasn't aware that the LT5 was available with a manual
Baby Blue
Old 03-13-2023, 08:17 PM   #17
Sephx1
Sephx1's Avatar
Drives: 18 ZLE, 18 SS1LE, 16 SS, 23 ZL1
You really should use a flywheel lockout tool when removing and installing a balancer. Thats A GM SOP
Yes I saw that. The OEM TTY bolt calls for 240 ft/lbs so we didn’t think 130 was going to be a problem.
Sephx1 is offline   Reply With Quote
Old 03-13-2023, 08:18 PM   #18
L78toLT1
L78toLT1's Avatar
The ZL1.
I put a ZL1 clutch in my SS. The SS and ZL1 clutches look and perform exactly the same, but there must be something different as they have different part numbers. My guess is the ZL1 pressure plate may use stronger springs.
Baby Blue
Old 03-13-2023, 08:18 PM   #19
Sephx1
Sephx1's Avatar
Originally Posted by AZ_1LE View Post
I'm pretty sure the OEM clutch uses centrifugal forces when spinning to provide more clamping power. I'd be real surprised if it was bad unless it has some sort of failure in the pressure plate (or disc?).
I hope you’re right.
Old 03-13-2023, 08:20 PM   #20
Sephx1
Sephx1's Avatar
We noticed right away it took more effort in my ZL1 than it did in my son’s SS. Not a ton of effort, but noticeably more.
Old 03-14-2023, 08:06 AM   #21
SteveV
SteveV's Avatar
Drives: 2018 ZL1 Camaro 6M Red Hot
Yup, there is a youtuber called street speed 717 with a manual ZR1.
Also, here is 1 for sale...
https://www.autotrader.com/cars-for-...ckType=listing
People are a lot like slinky's: not very helpful most of the time, but they bring a smile to your face when pushed down the stairs...
SteveV is offline   Reply With Quote
Old 03-14-2023, 09:32 AM   #22
BunnyBoy
Drives: 2017 ZL1
How the prices of these things have increased remind of the mid 2000s Ford GTs.
Man I wish I would have bought two and sold one to afford the other.
BunnyBoy is offline   Reply With Quote
Old 03-14-2023, 03:12 PM   #23
L78toLT1
L78toLT1's Avatar
Well, damn. If I'd known that I would have looked into an LT5 clutch!
Baby Blue
Old 03-21-2023, 09:09 PM   #24
Sephx1
Sephx1's Avatar
Took it to the track, clutch is definitely starting to slip. Ordered the stock clutch, pilot bearing, and actuator. Read as many clutch threads here as I could find. What other parts do I need? Does the flywheel need to be replaced or can it be resurfaced? I have the LT1/MM6 shop manual but not the LT4. Considering a subscription to the online manuals. I have done a lot of work but never replaced a clutch. Looks like 80% of the work is just getting to it.
Old 03-22-2023, 11:55 AM   #25
w.ross
Drives: 94 Toyota Pickup
I'm not sure about the replacement or resurfacing of the flywheel itself, but you probably will want to replace the flywheel bolts.
I've had the stock ones on Gen IV motors stretch and break during re-use. I can't remember if they are TTY or not? ARP may make some that are replacements for the LT's?
You won't have any trouble replacing the clutch given your history with this project. Good luck!
w.ross is offline   Reply With Quote
Old 03-24-2023, 10:19 AM   #26
Sephx1
Sephx1's Avatar
Thanks, I’m upgrading to the Katech flywheel. They recommend new stock bolts.
Old 02-08-2024, 11:11 AM   #27
sleepys4
Drives: CT5 BW
Bring back from the dead. Did you end up getting this sorted?
sleepys4 is offline   Reply With Quote
Old 02-11-2024, 10:54 PM   #28
Sephx1
Sephx1's Avatar
Yes, eventually it started working fine. Maybe just needed to get some time on it. Not slipping even with slicks at the track.
