Old 03-07-2023, 04:56 PM   #15
carguy55
carguy55's Avatar
Drives: 2018 1SS 1LE
I rebuilt my calipers with the GM vented pistons and high temp boots and they work great. Sold my Ti shims
Mods: MSD, Headers, 95mm TB, high flow cats, full 3" exhaust, SPL, MCS 2-way remotes, sway bars, rear diff lock outs, Sparco racing seats, 6 point harness, CMS roll bar, Nine lives wing, 6" splitter, ACS canards.
www.youtube.com/@Racer_Mike87
Old 03-07-2023, 07:09 PM   #16
5.M0NSTER
5.M0NSTER's Avatar
Drives: 2018 Camaro 1SS 1LE
Very cool! Where did you source those?
5.M0NSTER is offline   Reply With Quote
Old 03-07-2023, 07:15 PM   #17
dsm_mikey
Drives: 2023 Chevrolet Camaro ZL1 1LE
Are they aluminum or stainless pistons?
Mike
dsm_mikey is offline   Reply With Quote
Old 03-07-2023, 07:22 PM   #18
RamAir02
Shadow Gray '19 ZLE M6
RamAir02's Avatar
Drives: '19 ZL1 1LE M6
This thread has good info: https://www.camaro6.com/forums/showthread.php?t=613404
TL;DR
23242510 is the part number for pistons for SS 1LE calipers (J6M)
19207043 is the part number for pistons for ZL1 calipers (J6H)
YouTube
Old 03-08-2023, 12:39 PM   #19
carguy55
carguy55's Avatar
Pistons for the SS 1LE are GM 23242510 so any place that sales GM parts
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
The vented part is aluminum and the base is SS.
High temp boots for SS 1LE are from racingbrake.com
Old 03-15-2023, 02:14 PM   #20
badls1
Drives: 2019 SS 1LE MCS, SPL, V5-RS, FBO
Originally Posted by 20Bluezl1 View Post
I was going to swap them out also but the high temp boots had me thinking not a good idea snice they do t like brake fluid. Not like you should have fluid on them but when assembling if you just get some on them there done.
what about break assembly lube. Do break assembly lube destroys them as well?
badls1 is offline   Reply With Quote
Old 03-15-2023, 02:42 PM   #21
sr71bb
sr71bb's Avatar
Drives: 2019 Camaro Z-28
YES brake assembly lube will kill them also. I dont see that there should be an issue though regarding brake fluid. If brake fluid gets on them then that means the fluid got pushed past the piston seals and that should really NEVER happen. The silcone boots are simply dust boots to keep foreign matter out of the brake piston cylinders.
2019 SS 1LE BIG NA A10
Eagles Canyon Raceway 2.7 CCW Below
https://youtu.be/c9M5UHDftcA
4-15-23 at SCCA TT U1 Class
MEGA Thread on THIS car:
https://www.camaro6.com/forums/showthread.php?t=602092
Retired Cars BELOW:
1973 Camaro, 1969 Camaro, 1969 Camaro SS RS
2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10
sr71bb is offline   Reply With Quote
Old 03-15-2023, 09:09 PM   #22
carguy55
carguy55's Avatar
To put the seals in I used a little brake grease. If you follow the instructions its a non issue.
Old 03-16-2023, 11:09 PM   #23
GunMetalGrey
GunMetalGrey's Avatar
Drives: 2018 ZL1 (SOLD) 992 GT3 (current)
Originally Posted by sr71bb View Post
I disagree with this. There are LOTS of folks running DTC70 DTC60 combos and it works GREAT. 70% of your braking force is handled by the FRONT BRAKES anyway .
I’ve never understood this line of reasoning; This assumes that GM did not set up the brakes correctly from factory, obviously they already know how much bracing force is required from the front and the rear to stop the car in the best possible manner. I talked directly to Giro Disk, and they completely disagree with changing the pad Friction bias/ratio between the front to rear for the reason I just mentioned. They said make sure the pad friction is the same for the front and the rear.
I even took a step further and put DCT 70s on the rear and DCT 60s on the front (I was doing this because I thought I had over heating problems with the front rotors. Turned out to be a different issue completely and I was thinking a little oversteer would be faster.), however I wasn’t a fan of the slight corner entry Oversteer under trail braking.
2018 ZL1; Mag 2650 and 2 inch LT Headers , every SPL suspension upgrade, MCS 2 way coilovers, sway bars, square SC3R 325's all the way around, and multiple brake cooling upgrades
GunMetalGrey is offline   Reply With Quote
Old 03-16-2023, 11:16 PM   #24
GunMetalGrey
Originally Posted by dsm_mikey View Post
Good afternoon!
I have already purchased GIRO DISC front rotors and Hawk DT70 front and DTC60 rear brake pads. I plan on using Castrol SRF Brake Fluid with this setup. I also picked of Titanium brake shims for the front.
I stumbled across Racing Brake SS Brake piston upgrade (Remove factory brake pistons & seals and install these SS direct replacements) for our cars and I am wondering if anyone has used them and what the results are?
A couple benefits advertised with the kit I purchased:
1. SS Pistons (Stainless steel transmits heat at a rate of 10% v Aluminum)
2. The pistons are vented (Better heat dissipation)
3. High Temp Brake seals are included
If there are any negatives that I am missing, please let me know!!!
I have all of the brake upgrades you mentioned on my Camaro ZL1 including the much better brake air deflectors from the Cadillac CTV5, I wish I could tell you more about how well they worked for me however, I just finally got the 2019+ EBCM brake module to fix the real issues with my brake system (because I two foot), so hopefully after this track season, I can let you know more.
For what it’s worth, I have hawk DCT 70s on all 4 corners and a former race car driver who raced Indy lights with Danica Patrick drove my car and said “wow this car has demon brakes like a race car.” I was impressed that he was impressed
Old 03-16-2023, 11:28 PM   #25
GunMetalGrey
Originally Posted by khcoaching View Post
My SLE has ZLE front calipers, Giro rotors and stainless lines. I use Ferodo 3.12s in the front and 1.11s in the rear. Absolutely phenomenal brakes, zero issues. How good? When Randy Pobst drove it he said the brakes were "Incredible".
Ken
I’d like to know more about your experience with these brake pads, is there a reason why you use them in particular? They seem very expensive so I’d like to know more before considering purchasing them.
I currently use Hawk DCT 70s because they seem like a very good value, but I really don’t have any experience with any other brake pads other than stock factory ones, and would love to learn and know more
By the way, I think I saw your 1 minute 47 second lap time video at the ridge motorsports Park, if that’s you, seems like a great lap time for that car with those tires considering your horse power to weight ratio with those straight stretches! I’ll be going there this summer multiple times, hope to see you there
Old 04-24-2024, 04:14 PM   #26
speedrico
Drives: 2014 Cadillac CTS V-Sport
Hey there, CarGuy55,
Are you showing that you put the C07 Z07 CCB pistons in the SS-1LE rotors, and they fit just fine?
I read there was talk about them being 2mm taller and questions about it they'd fit with a new pad.
Also, anyone offer these for ZL1 rear calipers, other than RacingBrake? That shit is bux!
speedrico is offline   Reply With Quote
Old 04-25-2024, 04:35 AM   #27
carguy55
carguy55's Avatar
No the CCB brakes are different. The pistons I used are the same as whats on the iron rotor C7, Z06, GS and maybe others which uses the same size rotor ring, brake pad and caliper as the SS 1LE.
Old 04-26-2024, 10:23 AM   #28
Badmojo
aka BeastZL1
Badmojo's Avatar
Mikey,
I agree with using the same compound front and rear. If using Hawk pads, use DTC 60 front and rear. Allegedly, the 70/60 combination started with Mustang drivers and somehow became "the thing" to do. The seat of the pants feel is great, because it is aggressively shifting weight to the front of the car.
However, it is slower, harder on the brake system, unbalances the weight transfer, and is difficult to trail brake without over slowing. The Camaro doesn't benefit from moving the brake bias forward.
I've driven a ZL1 1LE with 70/60's and HATED IT. I switched to 60/60's and the car brakes just as deep without over slowing.
I haven't heard of this before...every car I have tracked I have done a more aggressive compound up front than the rear. Is this specific to the ZL1 1LE? Or Camaros in general?
I will definitely look into this...
I guess I don't understand how the rear brakes would get hot enough to move a higher compound if the fronts are working so much harder?
Either way, thank you for the advice!
2019 Camaro ZL1 1LE
Racing for ALS Youtube Link
