Old 02-19-2023, 11:04 AM   #15
jebfour
jebfour's Avatar
Drives: 2018 1SS 1LE
Thanks for the posts guys! Order placed!
Current
2018 1SS / 1LE
Previous
1967 w/ 327 & M21
1968 w/ 302 & M21
1968 RS/SS w/ 383 & M22
1986 IROC Z
jebfour is offline   Reply With Quote
Old 02-19-2023, 02:54 PM   #16
johnd5412
Drives: 2020 LT1 convertible
Just got a 7000TL a few days back. Its a pain to assemble but take your time and get the teflon tape correct. Most say don't use the liquid sealant they provide so I didn't. I used mine yesterday and it is everything I had hoped for. you won't regret the purchase.
johnd5412 is offline   Reply With Quote
Old 02-20-2023, 11:03 AM   #17
clg82
Drives: 2020 Camaro ZL1
What did you use in leu of the liquid sealant if anything?
Old 02-20-2023, 11:17 AM   #18
jebfour
jebfour's Avatar
Uggh. Had an email this morning saying that the jack I ordered will not be available until at least April, which is extremely disappointing. I have a V/M and email into them. Really hoping this doesn't turn into a black hole customer service nightmare.
Current
2018 1SS / 1LE
Previous
1967 w/ 327 & M21
1968 w/ 302 & M21
1986 IROC Z
Old 02-20-2023, 03:30 PM   #19
jebfour
jebfour's Avatar
Their C/S Rep. had a great solution. So excited for these to arrive!
Current
2018 1SS / 1LE
Previous
1967 w/ 327 & M21
1968 w/ 302 & M21
1986 IROC Z
Old 02-20-2023, 05:01 PM   #20
willzilla
D3RPZILLA
willzilla's Avatar
Drives: 2021 Camaro ZL1 a10
I used the liquid sealant. It works fine IF you apply it and WAIT.. like 24 hrs, soooo.. many of the issues with it was from people applying it and waiting zero minutes and continuing on with the install many just use teflon tape or something like that as it's quicker.
Website: z1lla.com | YouTube: sub.z1lla.com | Merch: Shop & Etsy
YouTube Playlists: Performance Mods | Show Mods | Other Mods
willzilla is offline   Reply With Quote
Old 02-20-2023, 06:09 PM   #21
RamAir02
Shadow Gray '19 ZLE M6
RamAir02's Avatar
Drives: '19 ZL1 1LE M6
Originally Posted by 302crossram View Post
Is there enough clearance for a creeper to be used ?
Yes, I use a creeper with mine and there is plenty of clearance. It's actually the perfect height on a creeper to work on your back and have everything within arm's length.
YouTube
Old 02-21-2023, 07:07 PM   #22
johnd5412
Teflon tape, 3 wraps in the direction of the spiral.
Old 02-21-2023, 07:11 PM   #23
johnd5412
Don't get that excited....if you don't get the assembly correct, i.e. sealant/tape, bleeding the brakes, fitment under vehicle correct you will have problems. I saw a video of a guy that took a week to work out all of his bugs. Take your time (plan 3 hours) with a clear head and you can do it no problem. Read the instructions a few times and watch a few videos beforehand. Saw a video of a guy that dropped his car b/c he let one side click in on the lock and not the other...he was ok but it could have been bad.
Old 02-21-2023, 09:03 PM   #24
ParisTNDude
Owning SSes for 50 Years
ParisTNDude's Avatar
Drives: Sharkskin Grey LT1
Originally Posted by willzilla View Post
I love my QuickJack I did a pretty in-depth setup and install video on the 7000TLX which works perfect lifting my ZL1 I use the zl1addons pinch weld lift point mounts with them hooked to the rear pinch welds and the second back front pinch welds.
When lifted at max height and on the locking bars I slide a set of stacked race ramp wheel cribs under the tires for extra safety in the event somehow the lock bars explode during a hurricane or something haha.
As for the TLX type series they add more lift height which is always nice! Def worth the extra few bucks. Also, I'd recommend grabbing their wall mounts which lets you mount the frames to the wall when not in use.
Here is the video I did on the QuickJack:
Here is a quick YouTube "short" video of me lifting up my Camaro (sadly this forum only puts a link to the clip and does not embed shorts for whatever reason):
https://www.youtube.com/shorts/Wn_noH7oT1w
Great video. I've had mine for a year now. Did tons of work under my 55 Delray and just now will be moving the quickjacks to my new garage. I expect my side skirts in tomorrow and hopefully, I can use the QJ.
I understand the anxiety of the first lift...you were breathing a little hard and so was I, but once I got the car in the air, all of my fears were for nothing. These are very nice for our under the car DIY projects. Thanks for sharing.
The new ride: 2023 Camaro, LT1, Sharkskin Grey
Previous Performance Cars:
1966 Chevelle SS 4M, 2010 Corvette 6M
1968 Dodge Charger R/T Auto 2012 1SS 6M
1982 Corvette Auto 2010 1SS 6A
1984 Corvette Auto 2016 2SS 8A
1999 Camaro Auto 2017 HBM 1SS 1le
2002 C5 Corvette 6M 2018 2SS
2006 Corvette Auto 2023 Camaro LT1
ParisTNDude is offline   Reply With Quote
Old 02-21-2023, 09:10 PM   #25
RamAir02
RamAir02's Avatar
I've had my QJ for 3 years now. It's been rock solid. No leaks.
The extended frame length is the way to go on our chassis given the distance between the lift points. Mine is the 5000EXT. That would translate to 5000TLX in the newer models which I believe are similar length, but a couple of inches more lift height.
YouTube
Old 02-21-2023, 10:54 PM   #26
willzilla
D3RPZILLA
willzilla's Avatar
Thank you! And yeah.. I was def sweating it on the first lift. I still triple check every time I go to lift the car and lower it haha.
Old 02-22-2023, 09:45 AM   #27
clg82
Their website is very confusing, it says "In Stock" for the 5000TLX but then when you go to order it, it says "pre order".....umm which is it?
Old 02-22-2023, 09:04 PM   #28
ParisTNDude
All you need is a hole in your floor board or worse yet, a bent frame. I always do the triple check thing before lifting..
