Old 04-05-2023, 05:44 PM   #15
Davescamaro
Drives: Chevy camaro
I've noticed with larger intercooler piping and tune with bigger amount of psi compared to stock, the turbo does spool up a bit quicker and Temps have dropped a wee little bit. I wouldn't say I've increased alot more in horsepower, but my ETs have been consistent compared to stock where it moves .1 seconds in the 1/4 mile.
2019 Camaro 1 LT 2.0 Riverside Blue Metallic, ZZP strut bar, K&N intake, ZZP catted DP, MRT axle back, Injen IC piping, Trifecta Elite tune, zzp heat shield, turbosmart diverter valve.
Knockoff zl1 sideskirts, gm front chin spoiler, 1le blade spoiler, diode sides, 20" staggered Asanti black labels, azenis 510 245/40/20 fronts, nitto 555 g2s 275/35/20 rears.
Davescamaro is offline   Reply With Quote
Old 06-30-2024, 01:52 PM   #16
buckwam
Drives: 2021 camaro 1ls
Originally Posted by Waleedriazz View Post
I also daily my vehicle and therefore, a large turbo investment wont make sense to me. Thanks guys, I'll just go with a diverter valve to minimize the turbo lag and a downpipe to increase flow. That should do me just enough, from what you guys mentioned (and from my own research as well).
I saw some pre- and post-downpipe dyno and am satisfied with the outcome. Worth the little bit of extra power!
How is the diverter valve performing by now? Did it throw any CEL or other problems? Is this what you have?
https://www.phastekperformance.com/g...1-camaro-2-0t/
buckwam is offline   Reply With Quote
Old 07-01-2024, 09:00 AM   #17
Davescamaro
That's not what I have. It's the turbo smart kompact diverter valve. No CEL from it so far. You can use the gfb adapter if you want a little whoosh sound. I prefer the turbo smart one. It's clean and loud whoosh.
Old 07-01-2024, 09:59 AM   #18
Start The Machine
Start The Machine's Avatar
Drives: 2016 M6 2.0T
What model do you have?
Dual Port / Vent To Atmosphere: TS-0223-1087
Plumback / Recirculating: TS-0223-1287
Also, are there any performance advantages to replacing the existing JacFab Recirculation Valve I'm currently running? Is the Turbosmart the exact same thing as the JacFab one, but just allowing a "woosh" noise? so, it's just a $300.00 woosh noise maker?
RS Package, HD Cooling Package, Brembo 6 Piston Front Brakes, SRP Racing Pedals, Soler Performance Throttle Controller, Dyno Tuned by Trifecta, Velossa Tech Ram Air, Mishimoto Intake, aFe Air Filter, Mishimoto Charge Pipes, ZZP 67mm Throttle Body, Trifecta T40 Stage 2 Turbo, JacFab Recirculation Valve, PTP Turbo Blanket, ZZP Catted Downpipe, Mishimoto Pro Cat-Back Quad Tip Exhaust, Mishimoto Catch Cans, Mishimoto Coolant Reservoir Tank, GM SEMA Grill, RPI Designs SS 1LE Front Fascia Extension, Ikon Motorsports 1LE Spoiler, American Authority ZL1 Side Skirts, AMPP Quad Tip Rear Valance
Start The Machine is offline   Reply With Quote
Old 07-05-2024, 04:40 PM   #19
Davescamaro
I have the kompact dual port. It sounds clean.
Old 01-30-2025, 07:18 AM   #20
Waleedriazz
Drives: 2018 1LT Camaro 2.0 I-4
Update: got a ZZP downpipe, GFBits Diverter and retune. No dyno yet but went from 5.6 secs stock to 5 secs on 0-60 mph (same tires, more worn than before if anything). Clearly more power than before!
Waleedriazz is offline   Reply With Quote
Old 03-23-2025, 03:18 AM   #21
Waleedriazz
It's a great, cost-effective edition. The turbo lag still exists, tbh, but the pick is quicker once it's built. No CELs, tune upgraded for free by trifecta.
Old 04-02-2025, 09:54 AM   #22
buckwam
Is is possible to run flex fuel on 2021+ cars? This is the best bang for buck upgrade possible, right?
Old 04-02-2025, 11:58 AM   #23
Waleedriazz
2021+ LTG don't have that option. SS and ZL1 do, from what I know. And it may be the best bang for buck, but it's not available anywhere in the region I live (GTA, Canada).
Old 04-03-2025, 11:42 AM   #24
buckwam
What would happen if you filled up with 50/50 e85 and 93 gas without a tune?
Old 05-04-2025, 12:05 PM   #25
buckwam
Just installed one yesterday. No CEL after short shake down test drive. One thing I did noticed when installing the diverter valve, was a small amount of oil at the turbo inlet after removing the intake tube. I have the mishimoto pipe and wondering if a catch can would prevent oil from entering the turbo. Never have to add any oil between changes, so not a huge amount. Is a catch can a good idea? The LTG project facebook site recommends Tracy Lewis catch cans as better than others. Is this true or marketing?
Old 05-04-2025, 08:27 PM   #26
bishopts
bishopts's Avatar
Drives: 2017 2ss 6mt
Catch can never hurts. I would recommend mishimoto. They did their homework on the design. There is a pcv valve you can't see under the valve cover. It has a hole coming from the pvc channel directly into the intake. All other brands have nothing to direct that path through the catch can. It looks like an odd shaped Y. You take out a service plug at the center of your valve cover above the intake and the Y goes in that hole to redirect it through the catch can. Its expensive compared to others.
Old 05-04-2025, 08:42 PM   #27
bishopts
bishopts's Avatar
As you can see in the xray picture on that pcv valve, its a very short path from the valve cover to the intake manifold without the mishimoto valve in place. The other option would be pull the valve cover and disassemble the pcv path to gain access to that hole to block it off. Then put a threaded barb in place of the service plug that you can run a catch can hose to.
Old 05-08-2025, 12:34 PM   #28
buckwam
Has anyone tried this catch can install?
