#15 |
![]() ![]() ![]() ![]() Drives: 2020 ZL1 1LE Join Date: Sep 2012
Have the ZL1 add ons. In the front the fit is basically flush with the adjoining body around the pinch weld and "fit" as you might expect. In the rear they tilt inward unless you are picky about when you lock them down with the set screws so that they maintain a straight up and down with the pinch weld, basically touching the outside adjoining body but not the inner side. For me this meant facing the adjusting side (where the allen wrench inserts) of the set screws outward in the rear. With the ZL1 1LE lower cladding this is finicky work. But - once set work fine and I have left them on the car for many lifts.
#16 |
![]() Drives: 91 Z28 (x2), 92 Z28, 20 TrailBoss Join Date: Oct 2009
Wow! I ordered mine Wednesday. (black stealth). I must have got lucky and snagged one of their last sets!
2023 2SS 1LE Radiant Red
1100 10/28/22 3000 11/22/22 TPW 12/19 3400 12/14/22 TPW 12/19 3800 01/12/23 4150 01/17/23 4200 1/30/23 5000,6000 1/31/23 1991 Z28 Brilliant Red Metallic 1991 Z28 Arctic White 1992 Z28 Bright Red 2020 Trail Boss LT 6.2 Satin Steel Metallic 2007 Cobalt SS/SC Laser Blue Metallic |
#17 |
Heh, everything is back in stock, guess they might not have wanted to sell too many more sets with the 15% discount
#18 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '17 2SS convertible'20 Yukon Denali Join Date: Nov 2011
Has anyone used the standard model for a convertible. They say to only use the stealth model but I thought I remember people using the standard ones.
Richard
2017 2SS SIM convertible, A8, NPP, MRC, 56R wheels, GM CAI, Diode Dynamics Side Markers, Mamo Throttle Body Delivered: 08/15/2016 #TeamBeckyD |
#19 |
![]() Drives: 2022 Camaro ZL1 Join Date: Dec 2021
I bought the knockoffs from ebay. Half price and worked fine. I did grind down the extremely sharp point on the securing bolt tips a bit. Car has been jacked up and/or put on a lift several times.
Randy in Nashville
2022 Chevrolet Camaro ZL1 A10 2020 Ford Mustang Shelby GT500 2020 Genesis G90 Ultimate 2018 Porsche 718 Cayman GTS 2019 Mercedes-Benz SL450 2017 Corvette Grand Sport A8 2024 Honda Civic Touring 1971 Datsun 240Z |
#20 |
Electrical Engineer
I have the standard ZL1 lift pads and I almost wish they came down a bit more so they'd be both easier to see and they would protect the side skirt more when using with a jack stand. I actually lift with a separate pinch weld lift pad on my floor jack at the middle lift point (so the entire side lifts up) and use these lift pads for my jack stands.
1100: 5/3/22 . . . . . . . 2000: 6/25/22 . . . . . .4000: 8/17/22 . . . . . . . 6000: 9/10/22 Daily Driver mileage update: 64k mi. @ Apr 2026 New Engine @ 22,600 mi. due to dealer confusing bad gas with a bad engine. Build Log: https://www.camaro6.com/forums/showt...6#post11353116 |
#21 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: Wild Cherry LT1 Join Date: Dec 2016
#22 |
Old Gearhead
Drives: 2023 GMC Sierra Denali Ultimate Join Date: Nov 2018
Anyone using hockey pucks? I'm thinking of getting 4 and cut a groove in them to fit. Yes? No?
2023 Camaro ZL1 convertible - black - SOLD
2025 GMC Sierra Denali Ultimate - black - 3.0l diesel 1937 Ford Slantback |
#23 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS 1LE Join Date: Oct 2011
I'm really glad I bought the ZL1 pads though, much faster and much less worry. I can change out my winters super fast now.
2018 2SS 1LE 2023 Colorado ZR2 2022 Stinger GT-line AWD |
#24 | |
Thank you Al Oppenheiser!
![]() EDIT: with pic
#25 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 1SS, 2010 Camaro SS Join Date: Apr 2012
FREE Shipping at Phastek.
https://www.phastekperformance.com/Z...a-01112304.htm |
#26 |
![]() Drives: 2017 Camaro 1SS Join Date: Mar 2019
do you guys keep these lift pads on even when you take the car to the track?
#27 | |
The product description says, "These are great for customers that change wheels at the track." The grammar police will tell you that it should say, "customers WHO change." LOL.
Soler DLX Bluetooth Throttle Controller / OFFKAT Smoked LED Side Marker Lights / Blue SS emblems on front & rear / Wildhammer Rear Dark Reflectors / Trim Illusion Gloss Black Door Handle Covers / eBay Black Fuel Door / Screaming Chicken Fender Hash Marks / Color-Matched G2 Caliper Paint CT Sounds Tropo 10" Sub / Down4Sound MM1000 Mini Maxx amp / JL Audio LoC-22 line output converter / Sub Thump Plug N Play T-Harness With ANC Defeat Harness Kit My Camaro Journal |
#28 | |
![]() Drives: Chevy Camaro ss Join Date: Nov 2022
This what I do too. It works good. |
