#15 | |
![]() ![]() Drives: 2004 BMW 330CI, 2022 1SS 1LE Join Date: Dec 2021
Wouldn't the grip just go away and that's when it's time to change them? What other queues do you use to know they are done? Wouldn't you just count the heat cycles? Lot's of questions I know, I'm getting mine mounted tomorrow. |
#16 | |
LT4 M6
Drives: 2018 ZL1 1LE Join Date: Nov 2010
I get roughly 6 to 10 sessions out of a set. Depends on the track. When I see cords I change them. |
#17 | |
![]() ![]() ![]() ![]() Drives: 2019 Camaro Z-28 Join Date: Jul 2010
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 |
#18 | |
#19 |
Where did you buy from?
#20 |
Was lucky enough to be able to get them from a friend.
#21 | |
![]() Drives: 1LE Join Date: Dec 2016
on getting the most out of consumables. This takes effort in rotating brake pads and tires to get the most even wear. It also requires a precise alignment and a tire pressure regimen. I find slicks to be gradual in nature (they gradually come up to temp (traction) and gradually lose grip (time)). It's pretty easy to tell when the last millimeter of rubber rubs away and the cords are showing. |
#22 | |
![]() Drives: 2020 ZL1 A10; Shadow Gray Metallic Join Date: Sep 2020
#23 |
#24 | |
![]() Drives: 2021 1SS 1LE Join Date: Nov 2020
Ken
Follow my build - https://www.camaro6.com/forums/showthread.php?t=594295
#25 |
#26 |
How were the slicks? I watched the video on the track time thread and it seemed rear grip was just ok?
Ken
#27 | |
I ran 1 session with my SC3s without trying to put down a fast lap 2 sessions prior and did a 41.2. I'll run new Hoosier R7s next time I go out for NASA TT. No rubbing or any issues with the 325s though, I had a blast. |
#28 | |
Ken
