#15 |
![]() ![]() ![]() Drives: 2017 Blue Camaro 1SS 1LE with PDR Join Date: Sep 2018
What car are you driving and what transmission? ZL1 1LE? What type of tires and what sizes? I think you will probably frequently get intervention in PTM Sport 1 when exiting a low speed corner near the limit of grip regardless of what you do with the LT4 engine due to the amount of horsepower. Cool tires will cause more intervention. I don't run Sport 1 even with my LT1 engine (about 200hp less than the LT4) because of excessive intervention although the intervention is a safety net and you will need to be able to catch slides by countersteering if you move to less intrusive PTM modes.
#16 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2018 Camaro 1SS 1LE Join Date: Sep 2018
#17 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
You can shorten the RF or lengthen the LF to move weight to the RF. I have a oval short track buddy with scales, I might get my car on them and try to tweak my car with me in it. I installed SPL endlinks.
"KEEP THE FAITH"-Fbodfather |
#18 | |||
![]() Drives: 1977 Pontiac Trans Am Join Date: Oct 2019
#19 | |
#20 |
305 square is less width than the ZLE's stock 325 width on the rears so that is probably contributing to your traction difficulties although a square setup is probably still advisable because the tires tend to last longer if you rotate them from to back. Also the car might be seeing slip that is not really there causing early intervention in Sport 1 because of the difference in wheel height/diameter if that's used in the PTM calculations.
The ice mode thread says that square setups are more likely to experience ice mode because of this reason so I would not be surprised if it impacted PTM too. |
#21 | |
I have run 3Rs on ZLE wheels on my SS 1LE at 5 different tracks for a few sessions each after running the majority of each event on stock SS 1LE wheels and stock SC3 tires. When comparing my best laps, I am about 2% faster (around 2-3 seconds per lap) on average on the 3Rs but I was only 1.3% faster at Barber using PTM Race compared to having traction and stability control fully off at the other 4 tracks. That is with less camber than the ZLE can run and stock sway bars that are not ideal for the 3Rs from what I have read on these forums and stock brake pads and rotors that sometimes can't fully utilize the available grip of the 3Rs under braking and stock MRC shocks. So I would expect the % difference between Pilot Sport Cup 2s and 3Rs to be larger for a ZLE especially because of the ZLE's extra horsepower compared to my car. My car's PTM is programmed for the grip of the stock SC3 tires so PTM Race on a ZLE with 3Rs would probably not have such a big lap time difference compared to traction and stability control fully off. In PTM Sport 1 on a ZLE, I don't know if you would see much benefit on 3Rs compared to using Pilot Sport Cup 2s or other tires on the Super 200 list in the attached image (from the article I linked above) but that doesn't mean their potential pace is actually very close. If you check the Best Track Times thread, I haven't noticed any PDR videos posted by ZLE drivers using Sport 1 near the fastest times for the tracks that I have checked in the past, probably because it is faster to use PTM Race or turn traction and stability control fully off but that does increase the risk of losing control of the car if you make a mistake. There is nothing wrong with using Sport 1. I guess I'm just trying to point out that it might be holding you back more in your corner exits than any of the rear sway bar settings would. |
#22 |
For rear tire pressure on both SC3s and SC3Rs I target 34-35psi hot at the end of the session (same for front) per the manual but others prefer 32psi hot. I can typically notice a loss of grip at 37psi and higher on SC3 tires on track. If you go too low you might cord the edge of a tire with a significant amount of tread remaining due to rolling over past the edge of the tread blocks and onto the sidewall while cornering but that is probably more of a concern with the front tires. Goodyear tires have a shoe with wings logo imprinted into the sidewall as the maximum point you want to roll the tires over which can help you judge your air pressure.
#23 | |
![]() I also have SPL endlinks, will have to give it a shot.
#24 | |
![]() Drives: 2017 Camaro 1SS Join Date: Mar 2019
I think the choice I made worked out. These tires stick! I just need to buy the set for the front tires but i will probably use the same tire size that the 1LEs use up front and not a square stance. |
#25 | |
#26 | |
#27 | |
I am going to try lowering the initial pressures as I am getting to 35-37 hot pressures to see if it helps. Thanks for the input. |
#28 | |
Weird lol .. 3Rs warm up in the first run for me less than midway through the run. I usually run hot tire pressures in the rear at around 30 psi and fronts I run at 32 PSI Below is my rear tire.. look at the Heat mark |
