#15 |
![]() ![]() Drives: 2017 ZL1 Join Date: Jan 2017
I'm trying one of the fender mount 2 gallon ones, they are shielded a bit better from heat, will report back with thread.
#16 |
Mine made 50 whp more yesterday with ice than with ambient water. To me, this was always between an interchiller or ice tank.
2020 ZL1LE A10.
LME LT4 390 short block, LME CID Heads, Kong E2650, FBO. 15" conversion, MT ET Street R 325/15. 100 octane: 1045hp/1055tq. 100 octane + Meth (1x10+): 1117 hp/1067 tq |
#17 | |
Dyno Show Queen LOL
The stewart IC pump is 400 new on ebay 10 instock The fittings are kinda expensive and hose is pretty cheap at place like stewart hose. also the power grip hose clamps are nice. With the run of the hose and the tank I bet you can increase capacity to 6.5 gallon. I was gonna do the fender and or bumper tank but, then I saw the price and the low capacity it offered and thought that was nuts and it would not be near as good as this setup for similar price. https://www.camaro6.com/forums/showthread.php?t=586298
#18 | |
Having FUN in the SUN...
![]() Drives: 2022 M6 ZL1 1LE Join Date: Jan 2022
Me too... Looking forward to seeing results. But my original post was trying to keep the fans on, after shut down... I think all of the underhood components will last longer if the engine bay can vent for 10min +/- after shut down...
2022 M6 ZLE: GMS Stage.III KONG X.PORT Package + DMS Lid + GMS Rear Bumper Belly Pan + GMS Hood Bracket + GMS Flex Fuel Package + MONSTER Triple S Clutch + XDI.50% Injectors + CLICK FOR BUILD LIST or www.GRIFFIN-MOTORSPORTS.com = 915rwhp 850rwtq + E60 + 15psi
#19 | |
#20 |
Dyno Show Queen LOL
Well that sucks..
#21 | |
Super Stock
Drives: Chevrolet Camaro ZL1 Join Date: May 2022
758 HP/ 804 TQ |
#22 |
You're probably going to need a generator and battery charger, or a 60a battery if you plan to do a lot of this
2020 ZL1LE A10.
#23 | |
Super Stock
Maybe not worth it all? I'd just would like to cool down things in the engine bay post shut down a little bit to prevent heat from staying in there and cooking literally everything. Lol.
758 HP/ 804 TQ |
#24 |
![]() ![]() ![]() ![]() Drives: 2019 Chevy Camaro ZL1 M6 Join Date: Jul 2019
I think the more practical, mechanical upgrades are the way to go. Prevent excessive heat build up during operation. Stock pulleys, increased coolant capacity and ceramic coating all of the exhaust pieces.
#25 | |
I can't imagine that running the fans at 50% for 10min would hurt anything, or drain the battery to a level that would not re-start. I don't know enough of the numbers to do the math myself... Battery Ah capacity vs minimum CCA needed to start and the Ah useage of the fan at 50%...
#26 | |
![]() ![]() ![]() ![]() ![]() Drives: 2019 ZL1 Join Date: Mar 2019
If your at the track. Then that’s a different story. Then a large trunk tank with ice is what you need or an interchiller. Or simply opening the hood and running a jet fan on the motor.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
#27 | |
Super Stock
All this being said, however, I have no idea what the specs on the trunk mounted battery in our cars is so I currently have nothing further to add or contribute until I get that information.
758 HP/ 804 TQ |
#28 | |
Super Stock
(No sarcasm intended btw)
758 HP/ 804 TQ |
