Old 08-30-2022, 09:34 AM   #15
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
I think I recall JRE saying that the OEM cats-pipes really start retaining heat, and that heat starts working it's way back toward the exhaust ports. Then, you have to start pulling timing because that heat start affecting the combustion chambers.
Just passing along what I've read.
'20 ZL1 Black "Fury"
Old 08-30-2022, 09:56 AM   #16
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Yep...and the pipe itself before going into the actual converter necks down to under 2" in diameter. You can still make power on stock exhaust you just have to be careful. Mike Sitar went high 9's on 100% stock exhaust.
Old 08-30-2022, 10:37 AM   #17
JSH
JSH's Avatar
Drives: '20 ZLE
Originally Posted by asthmamax11 View Post
Any before and after dyno of headers on a supercharged setup ?
The hp gains from LT headers have been discussed here extensively. It's agreed to be one of the best early mods. +20 hp is probably a reasonable figure.
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 08-30-2022, 12:54 PM   #18
asthmamax11
asthmamax11's Avatar
Ok excellent
Supercharged setups produce alot more heat
Next question is would headers make you lose any boost ?
16 1SS M6 White
Magnuson 2.3 Heartbeat
Roto Fab
Hurst short shifter
#'s coming soon
Riaction coilovers
1LE sway bars
BMR mm
BMR chassis brace
02 Z28 M6 35th anniversary
80k miles
T-tops
Leather
Bolt ons
Daily Driver
Old 08-30-2022, 02:47 PM   #19
LT1ornothing
Drives: 2020 LT1 M6
[QUOTE=asthmamax11;11222307]Ok excellent
Next question is would headers make you lose any boost ?[/QUOTE]
Boost is a measure of restriction. The less restrictions the engine has, the less boost it reads on a boost guage. Boost is not "lost" after headers, the engine is simply no longer as restricted as it was before the headers.
Old 08-30-2022, 03:26 PM   #20
asthmamax11
[QUOTE=1LEornothing;11222382]
Ok excellent
Ok thanks for explaining
So turning boost back up to pre headers level would require more fuel ?
16 1SS M6 White
Roto Fab
Hurst short shifter
#'s coming soon
Riaction coilovers
1LE sway bars
BMR mm
BMR chassis brace
80k miles
T-tops
Leather
Bolt ons
Daily Driver
Old 08-30-2022, 03:41 PM   #21
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
[QUOTE=asthmamax11;11222402]
Actually, your boost number can go down with the headers and you might need MORE fuel anyway. Best description I’ve seen describes boost as “unused air”. So with headers your engine will become more efficient and use more air which would require more fuel. Hope that makes sense.
Old 08-30-2022, 04:57 PM   #22
KingLT1
KingLT1's Avatar
Loss of boost does not mean a loss of power if flow and and efficiency increased.
Old 08-30-2022, 07:48 PM   #23
Chrome383Z
Chrome383Z's Avatar
Drives: 2019 Camaro 2SS
Yup pretty basic. You could have 100psi through a 1” orifice and 10psi through a 4”. (I’m throwing numbers out). Airflow and fuel requirements could be the same.
2019 Shock 2SS A10. 2650@10psi/LPE HPFP/XDI+30/LT4 LPFP+JMS/Soler 95mm/Rotofab, E65, CSP 2” Headers/GESI GenII Cats. MM Wild/GM SG3 suspension/1LE Brakes, Velgen VF5 Wheels/GY SC3. JRE Tuned.
Chrome383Z is offline   Reply With Quote
Old 08-30-2022, 08:44 PM   #24
JSH
JSH's Avatar
Drives: '20 ZLE
The engine is just an air pump and greater volume per ms equals more power. We probably need a new thread for this topic though.
2020 ZL1LE A10.
Old 08-30-2022, 11:38 PM   #25
asthmamax11
Thank you guys
I think I need to brush up on basic engine physics
Good info here
16 1SS M6 White
Roto Fab
Hurst short shifter
#'s coming soon
Riaction coilovers
1LE sway bars
BMR mm
BMR chassis brace
80k miles
T-tops
Leather
Bolt ons
Daily Driver
Old 08-31-2022, 07:12 AM   #26
laynlo15
Drives: 2022 Lt1 A10
As King said, front cats are most restricted. If you can score some cheap new era cat deletes, do it. I'm going with 2" SE catless headers. I have seen the dynos and ET gains, and the long tube headers pick up power and torque everywhere on the powerband, n/a or blower. But the gains seem to be more noticeable on blower setups.
So your leaving the rear cats in tacked and just elimination the fronts, Correct? I'm assuming that makes it a little louder.
Old 08-31-2022, 07:43 AM   #27
LT1ornothing
Drives: 2020 LT1 M6
No, I am going with Offroad 2" Longtubes into stock non npp suitcase muffler. I would not know about the volume increase of a primary only removal, but that sounds logical.
