#15 | |
![]() ![]() ![]() ![]() ![]() Drives: 2019 ZL1 Join Date: Mar 2019
I’m not going to critique his tune but there’s many adders that are still in your tune that myself and others usually zero out. On one of your logs I believe it was hitting 28.5 or even 29 at one point at 6700rpm. I see no real point mixing it to e60 with timing where it is, it’s quite possible in your tune it’s not even increasing past 50%.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
#16 | |
less worry more driving. Now you can go port injection and make even more with a real low side
#17 |
![]() Drives: 2017 Chevrolet Camaro ZL1 M6 Join Date: Jul 2020
I am watching Greg install TOOHIGHPSI's PI system. It sure loooks cool.
JRE Terminator Rough Idle Cam
Magnuson 2650 - 15% lower, 90mm upper FIC+30% DSX Flex fuel/Low side NW 103mm TB/Roto-Fab CAI Monster S Series Elite E2-X 2" TSP LT's BMR:BK063, BK060,TCA061, UTCA060, UTCA063 Weld Beadlocks/17" NT5R2 |
#18 | |
fo'shizZL1
Drives: 2017 ZL1 Join Date: Aug 2017
Mods being installed- oil pump, cam, ported heads, dual in-tank, Goliath and XDI, corn, etc., etc. |
#19 | |
#20 |
![]() ![]() Drives: 2017 ZL1 Join Date: Jan 2017
I'd say (being my own personal tuner, lol) that 28 is spicy but not stupid on your fuel ethanol content, I'd be interested in seeing how "detuned" your knock sensors are. The SS guys gotta remember our compression is lower on LT4 than LT1 to start with among many other things
![]() For comparison I'm @ around 23-24° @ 7,000 RPM on pump 93 and some 50/50 water meth on my daily driver tune. I've been a couple degrees higher on the dyno to see how it responds with the same octane/meth setup.
#21 |
fo'shizZL1
I'd say 28-30 is definitely on the full spicy end compared to most, based on my limited experience. I usually see guys ending up around 25-27 where they stop picking up any meaningful power on E. But I'm certainly just a "fella" who calibrates stuff and not a professional. That said, I trust myself over many "professional" tunes I've seen. I'd have no issue with Ted tuning my car though!
#22 | |
#23 | |
And, being a "fella" is cool. If it weren't for us, shit, we wouldn't have anything to argue about.
#24 | |
Pull a plug for me, let's see where you are really timing wise... take a picture of the strap and where the strap comes off the base of the plug. None of the #s matter, this is the ultimate truth.
#25 |
Red Bull
Drives: 2017 Chevy ZL1 Join Date: Dec 2020
Are you running the DSX low side and the jms voltage booster together?
#26 |
Nope. Removed the JMS and installed the DSX.
#27 |
I ran 27 degrees on my 16 SS 2650 Maggie with VP MS 109. On my 16 C7 we ran 28, it was an NA bolt on E65. My 2022 Lt1 with Lt2 on E65 we are running 28 total, 23 GM and 5 added for the E65. I don't know what we'll run when we get the Maggie on this car with toohighpsi port injection. We'll find out next week when we get it on the dyno. I'm guessing 26 to 27 on it also.
#28 |
![]() Drives: 2010 camaro Join Date: Dec 2017
timing is high like others are saying. It will Live if your on e50 forsure, but 28 on lt4 is really spicy! If you run that car hard take it easy after doing a 3-4 pulls.
