#15 |
Mike has it calculated with a 98mm upper and a 15% lower it should be around 10 lbs. I should be in the 600 rwhp range, maybe 625? Not sure.
#16 |
Previously CS10SS
Drives: 2017 ZL1 A10 Join Date: Jan 2017
I'll snap some better pictures of the engine bay & post them up now that I have the car back. In the meantime, here are a few more of how they ran the fuel system and Holley ECU.
No joke... the whine is so freaking pronounced now.
'02 Trans AM - sold
'05 SRT4 - sold '05 STI - sold '96 300ZX - sold '10 2SS/RS M6 455rwhp - sold '13 ZL1 M6 720rwhp - sold '17 ZL1 A10 930rwhp - Katech Built |
#17 |
I am going to guess 625-630whp.
#18 | |
![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 2SS A8 Join Date: May 2019
Yes I’m definitely going PI without a doubt. I only let go of a nickel to get a better grip. I’ve been down the road of doing a project more that once on the same car. That always leads to a redo that is wasted money and time. It never fails and it has either come down to poor research on my part or something better coming along at a later date.
#19 |
![]() ![]() ![]() Drives: 2020 LT1 M6 Join Date: Jan 2016
I would not be surprised if makes a little more than that. Should be a rocket paired up with your A10. Looking forward to how it turns out.
#20 |
#21 |
SNSTRSS
Nice setup. Do you know what AN size is the fuel lines? Does the fuel go to the front of the fuel rail and then through it to the flex fuel sensor? It looks like fuel would go through the rails before ethanol is read. Unless I'm just not understanding setup.
2016 Black Camaro 2SS A8 NP
#22 | |
I think they are AN 6s. The flex fuel sensor is in the back. Yes the fuel goes into the front of the fuel rails.
Here is the Corvette youtube explanation of the fuel lines. There is a Camaro explanation also but can't figure out how to get it on here from Instagram |
#23 |
I think I have a 105 if we are too high on the psi. I think 9 to 10 is safe and I'd like to be right there. I've already been thru a stock short block on my 16 because I couldn't stop running too much boost.
#24 | ||
SNSTRSS
Thanks for the Information.
#25 | |
![]() Drives: 2019 Camaro 2SS Join Date: Aug 2020
, I realized you have the 2300 so my post may not apply given that was with a 2650.
2019 Shock 2SS A10. 2650@10psi/LPE HPFP/XDI+30/LT4 LPFP+JMS/Soler 95mm/Rotofab, E65, CSP 2” Headers/GESI GenII Cats. MM Wild/GM SG3 suspension/1LE Brakes, Velgen VF5 Wheels/GY SC3. JRE Tuned.
#26 |
Well I did have a 2650 on my old 16 SS, but yes this one is a 2300. I still think it will be the 98 mm but won't know till we can get it on the dyno or a street log.
#27 | |
![]() Drives: 1SS Summit White 6 speed Join Date: Jul 2017
Proper fueling is all that is needed
16 1SS M6 White
Magnuson 2.3 Heartbeat Roto Fab Solo Performance Cat deletes and Axleback Hurst short shifter #'s coming soon Riaction coilovers 1LE sway bars BMR mm BMR chassis brace Flow one 19" wheels wrapped in Mickey Thompsons 02 Z28 M6 35th anniversary 80k miles T-tops Leather Bolt ons Joy to drive this classic every day! Daily Driver |
#28 | |
Can't wait to see how well Laynlo's set up does. He seems to have a similar approach. |
