#15 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
Red high temp/high strength threadlocker. Permatex 27200 is what I use. The yellow is GMs threadlocker. Use atleast an 18-24" breaker bar. No impact guns, that is hard on bolts. You can turn the steering to access the bolts better.
"KEEP THE FAITH"-Fbodfather |
#16 |
![]() Drives: 1977 Pontiac Trans Am Join Date: Oct 2019
So after doing some work on the rotors this weekend with a rotor hone and a bit of sanding disk on a rolock. I am convinced that it is from moisture getting caught between the pads and the rotors after I got home from the track and washed the car and not from pad transfer from overheating the breaks during the track day. After using the hone and rolock. I can still see some slight pitting where the pad was stuck on the rotor. I cleaned things up as best as I can but you can still feel it slightly. I am going to put the old pads back in and run them for a bit to see if it wears out the pitting. One other person mentioned it but has anyone else had this happen? From now on after I clean up after a track day I will be sure to take the car for a spin to heat the breaks up and get the moisture out.
#17 | |
#18 | |
![]() ![]() Drives: 2004 BMW 330CI, 2022 1SS 1LE Join Date: Dec 2021
#19 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 2SS/RS Join Date: Dec 2009
Rotors
I had this happen on my 5th Gen when it sat for a few months while I deployed. It stuck so hard when it broke loose it tore a big chunk of pad out!! It took several hours of scrapping and sanding to get it about 80% then I drove/braked the rest out you cant even see it now.
Orange Krush II
#20 | |
#21 | |
![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 2SS A8 Join Date: May 2019
https://www.summitracing.com/parts/TTN-12024
#22 |
I am 100% convinced it was the wash after the track day that did it. I live about 2.5 hours from the track, so I loaded the car, drove home and unloaded the car before washing it. Everything was cool, car rides on trailer on the way home no brakes just strapped down. After wash I pulled car into stall and left, that was my mistake. I was out of town for about a week and then did not get back to the shop until the following weekend, so almost two weeks of the brake pads holding moisture close to the rotors. Put car back together last night and took for a spin and feels much better but still can feel it a bit but it should wear off at Daytona on friday in the first couple laps. As an interesting side point, I found this in the caliper when cleaning things up. That's a wheel weight, not sure how it got there.
#23 | |
#24 |
#25 | |
![]() ![]() ![]() Drives: 2017 Blue Camaro 1SS 1LE with PDR Join Date: Sep 2018
https://www.camaro6.com/forums/showthread.php?t=529603 https://www.camaro6.com/forums/showp...21&postcount=9 Last edited by cdrptrks; 08-04-2022 at 04:25 PM. |
#26 |
Drives: 2018 ZL1 1LE Join Date: Jun 2012
Last track season I was dealing with a front brake vibration issue also, me being a tech at a dealership assumed warped rotors but asked on here and ended up buying the brake hone, used it and tested it out and it was maybe 25% better but still a pretty heavy vibration.
Finally pulled the rotors off and turned them at work and found one was still very true and straight and the other was warped. Turned both with a light of a cut as I could (to keep as much material on the rotor as possible) and they have been great ever since. |
#27 | |
![]() Drives: 2020 Chevrolet Camaro Coupe 2SS 1LE Join Date: Feb 2020
#28 | |
