Old 11-13-2023, 11:02 PM   #15
NiickySaz
NiickySaz's Avatar
Drives: 2023 Camaro 1LT V6
Stupid question. What type of oil weight do you use? And have you ever noticed an unstable/inconsistent reading on the oil pressure gauge during the drive?
NiickySaz is offline   Reply With Quote
Old 11-14-2023, 08:33 AM   #16
SOCAL.M6.ZLE
Having FUN in the SUN...
SOCAL.M6.ZLE's Avatar
Drives: 2022 M6 ZL1 1LE
wouldn't a MM wild CC with vent do the trick?
Old 11-14-2023, 09:42 PM   #17
TheWildJarvi
Drives: Camaro SS 6mt
I'm actually thinking it's the j&l oil separator catch can that's causing my issues, I think the ports are too small, it looks like they actually makes a 3.0 version that looks like it has bigger ports.
I ordered an elite engineering e2x dual port catch can that I'm hoping resolves my issues. It will be here Friday and then after I install it, I'll bring it to the shop for the rear main seal replacement.
I am running the factory 5w-30 oil weight and when I data log on the car the oil pressure doesn't jump it's pretty linear with load/rpm.
TheWildJarvi is offline   Reply With Quote
Old 11-15-2023, 02:45 PM   #18
ctrlz
Some ideas in the below thread. Sounds like excessive crankcase pressure blowing out the seals.
https://ls1tech.com/forums/forced-in...ain-seals.html
crankcase, front main seal, oil, oil leak, rear main seal
