Old 04-28-2022, 02:11 PM   #15
CW3SF
CW3SF's Avatar
Drives: 2019 Chevy Camaro ZL1 M6
When I called Kong and discussed my build (stock pulley, fuel system upgrades and ethanol) he told me the X port was totally worth it and should add 40rwhp. I guess it totally depends on your build and your goals.
To me, if you plan to continue modding your car why wouldn’t you spend $500 and get it all done the first time. No brainer.
CW3SF is offline   Reply With Quote
Old 04-28-2022, 02:49 PM   #16
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
I was thinking the same thing.
'20 ZL1 Black "Fury"
Old 04-28-2022, 02:57 PM   #17
Z OH 6
Drives: 2024 CT5-V Blackwing
Depends on how dedicated you are to keeping the stock blower.
Old 04-28-2022, 05:56 PM   #18
JSH
JSH's Avatar
Drives: '20 ZLE
The combination of the KongX and GT100 added at least 150 to mine. HPE made 725/850 on 93 octane with a virgin OEM 1.7L and OEM TB.
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 04-29-2022, 10:14 AM   #19
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Agreed.
I know I hate doing the same thing twice, and paying a second time to do the same thing. That's just my crazy. Stock blower's gonna hit harder than other alternatives though. I wouldn't argue that.
Old 04-29-2022, 10:19 AM   #20
KamZL1
KamZL1's Avatar
Drives: Z06
Agreed.
so go x or nah lol
KamZL1 is offline   Reply With Quote
Old 04-29-2022, 10:51 AM   #21
Z OH 6
Agreed.
For me, the X port wasn't available when I modded my car, however the standard Kong port was worth about 30whp which seemed like a pretty decent bang for the buck at $1200 at the time I had mine done. I don't know that I would have paid another $500 for another 10whp. To really get the most out of the X port, you have to spin the blower really hard and then reliability becomes more of an issue along with IC temps. At some point, it just makes sense to go with the Maggie 2650. To continue to try to build a max effort Kong X port build means investing more in fueling too, at that point, might as well bite the bullet and go with the Maggie 2650 for the improved cooling. I just don't see the point in the X port unless you're trying to set stock blower records.
Old 04-29-2022, 12:07 PM   #22
KamZL1
KamZL1's Avatar
Drives: Z06
well the point I'm wondering is this: say I do same mods as you and go with standard over x and have no intention of spraying gallons of meth adding a death pulley, just want to land somewhere around 700, am I leaving anything on the table by not going with x? say I end up at 690 or however much you made, would you have seen 700 with the x? regardless of the fact that you don't plan on going full kill with the blower. because to me, if I'm going to do it, id rather not leave anything on the table and do it once
Old 04-29-2022, 12:53 PM   #23
Z OH 6
No, because you will land at 700whp with a standard port and bolt-ons at which point you'll be fuel limited.
Old 04-29-2022, 01:28 PM   #24
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
It also seems to me that unless a person really wants to say they got another 10-WHP from the X-port, it's almost just chasing dyno numbers. You can get more or less power just by changing the way you strap a car on the dyno, for example. You can loose dozens just by heat soak runs.
Don't get me wrong - I'd want to squeak as much as reasonable from my build. I wouldn't suggest there isn't a better way to spend my money, but that's just my OCD and wiring.
I was in a similar situation when I started thinking about what I wanted to do. The X-port wasn't available yet, but the cooling is what pushed me. Do I benefit from all the theoretical cooling it has (I say theoretical, but I see it in my logs - I just never compared to stock)? Nope. BUT - I'm getting all the power I need and know I'm not stressing anything except the rear tires, lol. That - and I couldn't get to this power without doing it this way.
Old 04-29-2022, 01:30 PM   #25
CW3SF
CW3SF's Avatar
I agree with this. You need the fuel system upgrades to make use of the X port. If you think you might upgrade fuel in the future I’d get the X port. I’m doing fuel also now and probably a cam down the road so the X port is worth it to me. It’s not the most cost efficient approach but that’s not my priority.
Old 04-29-2022, 01:56 PM   #26
KamZL1
KamZL1's Avatar
Drives: Z06
Yeah i fully plan on going cam/dsx maybe injectors later when i shoot for 800 ish, just not anytime soon.
Old 04-29-2022, 03:52 PM   #27
JSH
JSH's Avatar
Drives: '20 ZLE
Only the low side; high side is good with my build
2020 ZL1LE A10.
Old 04-29-2022, 04:03 PM   #28
CW3SF
CW3SF's Avatar
High side needs fuel upgrade also on a stock block. You have a cam with fuel lobe right?
