Old 04-01-2022, 02:55 PM   #15
BlueStreak91
BlueStreak91's Avatar
Drives: 2SS Vert
Originally Posted by DaveC113 View Post
Ok, well in that case you can figure out the minimum width rim required for those tires and the front offset required for that rim width. For example if you can use 10" wide rims you can use around 20mm offset, 11" wide rims need around 10mm offset. Again, check with Apex on exact numbers as you'd want to use the most offset possible so the rears don't poke too much. You'll still have more oversteer than you might want, which a staggered setup will balance out...
SO a set of 18x10 +33mm offset with 295 30 18's should fit for a square setup without any rubbing of struts or fenders?
TIA
22 2SS Vert, RSB, White Stripes over Ceramic White w A10, MRC, NPP, and more (built in Michigan)
71 Chevelle (built in Texas), 05 Yukon XL (built in Texas), 22 Corolla Cross (built in Alabama), and more cars for the kids
BlueStreak91 is offline   Reply With Quote
Old 04-01-2022, 02:59 PM   #16
BlueStreak91
Drives: 2SS Vert
Also, I'm not opposed to some thin spacers so I retain the stock studs.
Old 04-01-2022, 04:00 PM   #17
VR Baron
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE
You can use a 3mm or 5 mm spacer. 5 mm is max though or you run out of enough threads to be safe. I use a 3mm and no issues.
VR Baron is offline   Reply With Quote
Old 04-01-2022, 04:27 PM   #18
DaveC113
DaveC113's Avatar
Drives: 2018 Camaro 1SS 1LE
TIA
I think that'll be super tight, 18s run into the strut a little more vs 19s. I'd consult Apex on that.
The wheel studs are pretty easy to do, takes an hour or so, no need to remove the hub. Then you could run 315/30/18 square.
Old 04-01-2022, 04:55 PM   #19
BlueStreak91
Drives: 2SS Vert
Great point - I love this place already.
