Old 03-25-2022, 08:33 PM   #15
SATINSTEEL1LE
Drives: 21 ZL1
Originally Posted by KaMaRow View Post
so me and my buddy have done the math. if you can follow LOL. He looked up all his receipts for his gas and his mileage. He has spent 440 dollars on going 2070 miles. My mileage is 37 gallons in 423 miles. so im at 166.50 dollars for my 37 gallons. our gas had been 4.50 give or take for the last week that i been driving. thats right at 40 cents a mile. so fo rme to drive the same 2070 miles he has i would have to spend 814.78 cents. dang near double which coincides with my average of 11.4 miles per gallon. which is about half what mpg hes getting.
we both live in same place on same roads in same driving conditions. and he actually is very hard on his car. something is wrong... I feel the bogging down on acceleration has something to do with it. its very hesitant to get up and move and when you do give it gas is sorta hesitates while my buddies car just takes off...
Pull the battery cable off and leave it for a few hours. Reconnect and rip it. This is not rocket science.
SATINSTEEL1LE is offline   Reply With Quote
Old 03-25-2022, 08:36 PM   #16
KaMaRow
Drives: Man
Send a message via ICQ to KaMaRow Send a message via AIM to KaMaRow Send a message via Yahoo to KaMaRow Send a message via Skype™ to KaMaRow
Originally Posted by SATINSTEEL1LE View Post
Pull the battery cable off and leave it for a few hours. Then reconnect and go rip on it. The fuel trims will learn and it will lean out and get proper gas mileage. Your baby driving is killing it. Stop that, this is not 1950 where you need to drive a car thousands of miles before you beat on it. Seat those rings and enjoy a healthy motor.
I thought of this. I know pulling battery does reset some stuff. would this also reset the transmission tables? why does everyone keep telling to to do the opposite of what Chevy says to do for break in? LOL
KaMaRow is offline   Reply With Quote
Old 03-25-2022, 08:39 PM   #17
Jaxcam02
Jaxcam02's Avatar
Drives: 2017 Silverado/2017 ZL1
You still getting winter blend gasoline in NC? I average 14.7 mpg and record all my fillups on aCar app
Jaxcam02 is offline   Reply With Quote
Old 03-25-2022, 08:40 PM   #18
KaMaRow
Drives: Man
So my buddy is reading up on others that have had the issue. some are saying could be a faulty injector? what do you all think. could that account for bad mileage and the hesitation and boggy feeling at starts. oh and it also sorta struggles to start a bit takes it a couple cranks to start does not start right up.
Old 03-25-2022, 08:41 PM   #19
KaMaRow
Drives: Man
I dont know? I mean we both get gas at same stations and he does not seem to have the issue.
Old 03-25-2022, 08:43 PM   #20
Mac7504
Mac7504's Avatar
Drives: 2003 Monte Carlo SS SLP, 2022 ZL1
Stuck injector?
Mac7504 is offline   Reply With Quote
Old 03-25-2022, 08:47 PM   #21
KaMaRow
Drives: Man
and just asking but what exactly does this fix? I mean if there is a engine problem which isn't out of the question. they do make bad cars from time to time.
Old 03-25-2022, 08:48 PM   #22
raptor5244
Drives: 2022 CT4-V Blackwing
When you pull the battery cable and let it sit for a bit, it should force the ECU to reset the fuel trim tables it has stored. When you reconnect and start up again it will relearn new air fuel mixture values based on your environment (air temp, humidity, etc.) It is not a bad idea from a troubleshooting perspective.
As for the break-in you will get a lot of differing opinions but do whatever you feel comfortable with. I took it a little easy for the first 500 and then found a few highway on-ramps and did some nice pulls. I was getting 3.7-3.8 0-60mph, 7.8 sec 0-100mph and 11.5 sec 1/4mi times using the built -in timer. That seemed about right considering I was spinning a bit during launch.
2019 Tesla Model 3
2022 CT4-V Blackwing - M6
Old 03-25-2022, 08:48 PM   #23
pauly1119
pauly1119's Avatar
Drives: 2018 ZLE
The best my ZLE gets is 14 mpg on average. My Z06 gets an average of 22 mpg.
pauly1119 is offline   Reply With Quote
Old 03-25-2022, 08:53 PM   #24
KaMaRow
Drives: Man
Originally Posted by Mac7504 View Post
Stuck injector?
this is a possibility from other stuff im reading.
Old 03-25-2022, 08:54 PM   #25
KaMaRow
Drives: Man
ok thanks yeah ill pull the battery in morning and give it a shot. I do have a obd reader ill use that in the AM cant hurt.
Old 03-25-2022, 08:58 PM   #26
KaMaRow
Drives: Man
I have also read several places something about bleeding some line on the supercharger that cause some acceleration issues? could this be the issue?
Old 03-25-2022, 09:15 PM   #27
Mac7504
Mac7504's Avatar
At this point I think you're getting way ahead of yourself. Take it step by step; reset your battery and see if that helps.
If that doesn't and you don't want to wait for break in period to be completed, take it to the dealer for them to check.
Just my take.
Old 03-25-2022, 10:05 PM   #28
discgolf01
Drives: 2018 ZL1 Convertible M6
I have an M6 ZL1 and like to hang out in 2nd gear all day. Numbers look about right to me, lol.
discgolf01 is offline   Reply With Quote
