#15 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2020 Camaro 2SS A10 Join Date: Jun 2018
This was yesterday: Which includes 1 or 2 measurements of 100mph windspeeds. 5" snow today so can't test today.
Yes I know I need to clean the display. :x If it matters filled Mother's car 2016 Trax LTZ with shell 87 and her gas mileage went up as well not by as much as mine but 1-2mpg. I do drive her car to work on bad weather days like today. She averages about 26-27mpg.
#16 | |
Hot Camaro
#17 | |
162 = 1/3rd of a tank of gas x mpg 19 gallon tank 19 x .33 x 25.5 = 162 (should equal 162) actually comes to 159.86 miles. Yes I realize the gas gauge almost never measures accurately. But given that margin of error the numbers are solid. That is a margin of error of 1.7% at the time the test was done. That test was my morning commute, driving to another work facility, and then driving home over the course of a 10 hour period.
#18 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: E92 BMW M3 Join Date: Oct 2012
For example...the vast majority of gas stations in the pan handle of Florida source their gas from the same lone terminal in that area. All the regular gas in that terminal shares the same tank, and the premium in its own tank, meaning the grades are homogenous up until the point in which that terminal injects the gasoline with additive. Same ethanol levels, same RVP, same everything down to the molecule. Some of our customers want 'top tier', so we give them that. But ALL top-tier from this terminal is identical too, so whether you buy it at the local Costco or somewhere else....its the same thing. We also dont use the same additives for 'top-tier' and 'branded' customers, so even if they perform similarly...they are still not the same molecularly speaking. I'm not conveying to what degree they differ, I don't work in our PQ department, and even if I knew I would not be able to share that level of detail.
J-Rod Built and Matt@FSP Tuned |
#19 | ||
Hot Camaro
19 x .375 x 25.5 = 181.7... Quite a bit different than the 162 you mentioned. Gauges are not perfect and are only an estimate (when you gauge says empty, you actually still have 1-2 gallons of usable fuel left in the tank). As I've said already, the only way to know your true MPG is by hand calculating from a full fill with each tank. Quote:
#20 | |
Sticking with my example, all coming from the same terminal and lets use Premium gasoline as well. We have 3 types of premium gasoline that will come out of that terminal. They will all differ based on additive type or concentration only, and before the additive they were all the same. 1 - You have just basic generic or what we call 'unbranded', which is like your Sam's or Costco regular gasoline but it is NOT the same as their Top Tier offerings. For this, the terminal owns the generic additive and as a point they only stock 1 type of generic additive. 2 - You have your Top-Tier, which uses the same generic additive as above owned by the terminal, but it is injected at about 2.5x concentration compared to #1 above. Same exact additive molecules but just in different concentration. 3 - You have your branded like Shell, Chevron, Exxon. To be clear and to address your question, this is NOT the same as Top Tier. They use a different additive than #1 and #2 above, even made by different companies in most cases and dose levels are lower like #1 above(not 2.5x like #2). From what I find and what I hear, the results of double or triple dosing generic additive(Top-Tier) like #2 has a very similar effect to gasoline injected with standard dose of branded additive like #3. I think that examples 2 and 3 show that while the results are very similar the end products are different in molecular makeup. That is evidenced by the fact it takes almost 3 times the concentration of generic additive to produce similar results as single dose of branded additive. Additionally, no matter what station you buy from in this geography of Florida pan handle, the above 3 choices are all you get. Generic from Albertsons is the same as generic from Sam's....Top Tier from Costco is the same as Top Tier from P66 etc etc. Lastly Shell gas is Shell gas, Chevron gas is Chevron gas, and Exxon is Exxon as their additives are all a tiny bit different but honestly it is so secretive we really dont know how different haha.
#21 |
Drives: Chevy Camaro 2021 ,rs, v6, manual Join Date: Feb 2022
I like to get fuel from the busyiest station for freshest fuel and run fuel system cleaner about 500 miles before oil change.
#22 | |
Hot Camaro
#23 | |
IF we assume the 25.5mpg is accurate and not the gas gauge. Realistically, the computer is going to know just how much gas went through those cylinders. And if the computer calculated a 25.5mpg average and also does not struggle with measuring distance considering I was on my stock wheels and tires all winter. Then my guess of a 1/3rd of a tank is probably more accurate than 3/8ths. Yes I probably just got lucky. But I also know analog gas gauges are off by about 2 gallons on average. I assumed the same for digital gas gauges. I have driven 600-700 miles a week since the beginning of December. During the month of February I was averaging 22mpg for 2400+ miles. All through December and January I was averaging 24-25mpg right up until I changed my oil. The only other difference was I was filling up my tank at work, rather than at home. At of the beginning of March I switched back to my home Shell V-Power 93 in my car and after 350 miles noticed my gas mileage went up by 3mpg according to the in car gauge that is. Now consider the mods I have on my car. The more you power mod your car the worse your gas mileage gets. Is that not generally the correct assumption? In my case my gas mileage got better after the mods and tune over the stock tune. Even on E85 If I drive sane I get up to 20mpg. If I drive insane I get 13-15mpg. Physics is physics, the rest has to be the Tune on my car, weather, and/or quality of gas. I think it would be a safe guess that we did get more snow in February than December and January, but then again I don't drive my car during bad weather? I dunno. I just feel like the particular Shell I go to makes a difference for me.
#24 | |
Hot Camaro
My Silverado shows a lifetime MPG of something like 17.5 or so in the dash (I never reset Trip 2). But calculated MPG over 90k+ miles of driving and fill-ups shows the real number to be 16.7. That's about a 5% margin of error which I feel is unacceptable. I always look at the trip rating when I fill up and compare it to what the calculate amount is. The delta between the two varies all the variance / error percentage doesn't remain the same either. I've had tanks that are very close (maybe a 1% margin) and others that are off by over 10% (truck showed 20 but calculated was under 18, for example). |
#25 | |
Going to buy a prius then power mod it with racing stripes and an 18" spoiler.
#26 |
![]() ![]() Drives: 2019 2SS Camaro Join Date: Apr 2012
I find the gauge to be extremely accurate. 1 tank 1 trip. wind and all kinds of factors play into it
#27 |
Hot Camaro
#28 | |
Drives: 2022 ZL1 M6/Nissan Leaf Join Date: May 2016
That's what I expect someone that works for the "Big 3" to say. :P Branded need to justify the extra costs, but as someone else has mentioned there isn't much of a difference. Hell, I used Shell Premium exclusively in one of my cars and then switched to Costco gas and didn't see any marked difference. One big factor is the gas station itself. Some shady stations will use water, while some have some very old gas tanks (I heard about a guy pumping rusty looking gas because of how old the tank was) some use a higher concentration of ethanol (not E85 but E15-E20, etc.) Those are sometimes lower cost, but will definitely show lower performance. I used to go to a Bucee's that was about 30 miles away to fill up with pure gas (no ethanol) and didn't see a difference there either, which was a little disappointing. I did decide to use the pure gas for all my lawn equipment though, as that stupid Ethanol tears through older lawn equipment gas lines like a Mustang through a crowd at a C&C meet. |
