Old 06-08-2022, 07:59 AM   #15
shinysun
Drives: 2016 Camaro SS
Originally Posted by Chrome383Z View Post
The JMS adapter wired into the 2V signal on mine. I thought it was 0-5v, but checking it I only got around 2 at wot. Maybe there’s another wire with a different signal? Wouldn’t think so but not sure.
(I don’t have smoothboost, I just checked the voltage at the JMS when I set it up)
Yap, there are 2 signals on pedal wires.
shinysun is offline   Reply With Quote
Old 06-08-2022, 09:01 AM   #16
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Originally Posted by shinysun View Post
You wired to the wrong one. I had the same issue, but it was my fault.
Ok, which wire did you use @shinysun?
Old 06-08-2022, 09:05 AM   #17
Joshinator99
Moderator
Ok, so my using the JMS t-harness didn’t help the situation…
Old 06-08-2022, 10:40 AM   #18
Chrome383Z
Chrome383Z's Avatar
Drives: 2019 Camaro 2SS
Wonder why there’s two different signals. Be interesting to know. Wish I could help on grabbing the right one. I don’t know.
2019 Shock 2SS A10. 2650@10psi/LPE HPFP/XDI+30/LT4 LPFP+JMS/Soler 95mm/Rotofab, E65, CSP 2” Headers/GESI GenII Cats. MM Wild/GM SG3 suspension/1LE Brakes, Velgen VF5 Wheels/GY SC3. JRE Tuned.
Chrome383Z is offline   Reply With Quote
Old 06-08-2022, 12:07 PM   #19
Joshinator99
Moderator
I think I need to grab pin 5 off the pedal sensor. My shop is good at wiring, so I'm bringing the car in Friday morning to get that squared away and I'll report back.
Old 06-09-2022, 01:16 AM   #20
shinysun
I am not sure at this moment. You better use a voltage tester.
I think I used the oppsite side of wire. for example , if you are using #2 pin now and it is 0~2V, the correct wire would be #4 in 5 pins.
I am also using JMS booster, and it is wiring to 0~2V wire.
I believe it is for the safty reason to have the 2 different voltage wires.
ECU monitoring the both and if there are some discrepency, the code will show up.
Old 06-09-2022, 07:26 AM   #21
Joshinator99
Moderator
I’m pretty sure I have to use pin #5 (think I’m on pin #2 now) and will confirm tomorrow morning. It makes sense why GM had 2 signals though…!
Old 06-10-2022, 07:49 AM   #22
cjperformance
cjperformance's Avatar
Anyone try this on a centri? Was thinking about putting on a smaller pulley to build more boost at lower rpm with the procharger, but limit it at higher rpms to keep the engine safe.
I dont really NEED this... just bored right now and want to play with something.
DSX Aux Low Side | LT4 high side | Flex Fuel
TooHighPsi Port Injection (installed & tuning)
CircleD 3K Stall | QA1 CF Driveshaft
Forgestar F14 Drag 17x10 NT555R2 305/45/17 Rear
Forgestar F14 18x8 NT555G2 235/50/18 Front
10.84@131 w/4.13" pulley
??.??@??? w/3.7" pulley (installed & tuning)
Old 06-10-2022, 09:43 AM   #23
ZO6Ted
Old badass
ZO6Ted's Avatar
Drives: 14GMC 2.9 16GMC Turbos 2020Silv.6.2
Pretty sure ECS did this exact thing many years ago iirc correctly. They said it works.
I've had 7 Camaro's. All gone...for now.
Current build in progress 2016 GMC4x4 RCSB twin hair dryers ~1k whp fbe port inj 1/8 mi & stealth street terror
ZO6Ted is offline   Reply With Quote
Old 06-10-2022, 10:45 AM   #24
cjperformance
Smoothboost makes a centri boost controller for around $1K. This thread is how I learned about it. I might mess around with that sometime. I mean... that is the exact purpose of the kit... just... priorities.
Old 06-10-2022, 12:38 PM   #25
wnta1ss
Drives: 2017 Camaro 1SS
Guys have put a wastegate onto a centrifugal setup (charge tube makes it like a turbo system), and then you can use a boost controller. However, you should keep in mind that if you overspin the blower relative to your top rpm desired boost level, then you'd be heating the air up a little more than needed, as far as I'm concerned. My opinion, it's not worth the bother for your car. The low end on these cars does not last long with a 4.56 first gear, so the low-end torque difference of a centri from a pd/roots style is nowhere near as big a deal in the 1/4 mile as some try to portray. I learned that lesson first hand, as my base Paxton centrifugal blower with stock torque converter ran a much quicker 60 foot (1.63) than the 1.8 some say a centri would do. You've already added the stall converter to yours, so I am expecting you to easily get 1.5 short times on DRs while still using the base pulley.
Old 06-10-2022, 02:52 PM   #26
cjperformance
Good info. I do intend to get at least a couple solid baseline passes on the DRs (on the way) before I do any more changes. Otherwise... wont know if it does any good!
Old 06-10-2022, 05:57 PM   #27
Joshinator99
Moderator
So, just to confirm that you do indeed need wire #5 to get 4.0+ volts needed to fully extend the actuator. And the final result is PERFECT! Boost comes on much more smoothly and the tires are happier for it. Driveability is definitely better. Around town you can turn the dial way down, end up with just a few pounds of boost and still have more power than most cars on the road. And with the Kong-ported Whipple, boost is up from 14.7 to 15.9 at full kill! Looking forward to getting to back on the dyno and see where I ended up.
Old 06-10-2022, 08:16 PM   #28
shinysun
Congratulations!
