#15 |
![]() ![]() ![]() ![]() Drives: 2018 ZLE Join Date: Feb 2018
#16 |
TEXIT
Drives: 2019 ZL1 M6 Join Date: Aug 2018
If I recall correctly, there was a fair amount of sealant present on the tranny bolts from the factory. I didn't use any sealant, just snugged up the bolts. No leakage that I have seen.
#17 |
![]() Drives: 18 ZL1 1LE Join Date: Apr 2013
When I changed mine I ended up going with the fluid TREMEC makes for their manual transmissions. It’s a pain in the ass to refill. I recommend getting a fluid exchanger or a suction pump gun
https://www.tremec.com/menu/manual-transmission-fluid/ |
#18 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS 1LE Join Date: Aug 2013
#19 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2018 Hot Red ZL1 Join Date: Nov 2010
#20 | |
![]() ![]() ![]() ![]() ![]() Drives: 2023 CT5 Blackwing, 2025 C8 Z07 Join Date: Sep 2016
TREMEC won't have fluid for a while. The facility they used had a catastrophic fire. They are recommending Pennzoil Synchromax in the interim.
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 2025 Hysteria Purple C8 Z07 |
#21 |
![]() Drives: 1977 Pontiac Trans Am Join Date: Oct 2019
#22 | |
![]() Drives: None Join Date: Jan 2018
#23 |
![]() Drives: 2018 ZLE, 2023 C8, IMSA MX-5 Join Date: Jul 2019
We use one for gearbox and one for diff. Take off the nozzle and add your flex line, pump and dump.
