#15 |
Drives: 2017 Camaro ZL1 A10 Join Date: May 2012
The best thing to do is make sure it isn't a Tesla Plaid. Because ain't nobody beating them things at any starting speed.
#16 |
Moderator
Agreed. No big power car will voluntarily do a 30 roll race on the street, there’s just no traction. Even 40 is considered very low to start.
#17 |
This is the key to the hit - you have to be in the lowest possible gear or else mine will downshift one gear when I shift to Drive and roast the tires. 60 mph at ~5000 rpm should do it.
Of course, since, depending on your car's power, a 60-130 only takes 5-7 seconds, you can chose to make the hit in manual using HUD and make the 3-4 shift manually when you see the red warning lights, and not have to deal with kicking it into Drive.
2020 ZL1LE A10.
LME LT4 390 short block, LME CID Heads, Kong E2650, FBO. 15" conversion, MT ET Street R 325/15. 100 octane: 1045hp/1055tq. 100 octane + Meth (1x10+): 1117 hp/1067 tq Last edited by JSH; 01-22-2022 at 09:32 AM. |
#18 |
Drives: 2022 ZL1 M6/Nissan Leaf Join Date: May 2016
With the 10-speed, wouldn't it mostly depend on having it in the right gear? You don't want it in a gear so high that you're shifting shortly after, but you also don't want to be on the low end of the rev range, right? I say go drive at each of the speeds you asked about, and see where the transmission has the RPM at each speed. Look for the sweet spot based on peak TQ and that'll let you know where to start (pun intended).
#19 | |
![]() Drives: A Vette Join Date: Jan 2020
Good point thanks. |
#20 | |||||
I can't tell you how many times I practiced this because it totally makes sense, but reality is that 1st shift comes too quick and then getting it back in auto is a hit and miss. Quote:
#21 |
Again, all of this depends on the car. In my case, a 60-130 takes around 6 seconds. All I have to do is get to 60 mph at around 5000 rpm in Manual, make the hit, leave it in manual and make the one shift when I see red lights on my HUD. Any shift to Auto is problematic.
Of course the 87a TCM can be tuned to make these shifts while in Manual mode.
2020 ZL1LE A10.
LME LT4 390 short block, LME CID Heads, Kong E2650, FBO. 15" conversion, MT ET Street R 325/15. 100 octane: 1045hp/1055tq. 100 octane + Meth (1x10+): 1117 hp/1067 tq Last edited by JSH; 01-22-2022 at 05:07 PM. |
#22 | |
![]() I also agree 100% with your method for manual, and I mentioned as well that shifting to auto is hit and miss. But bliping the throttle gets you in that 4,500 range and leave it in auto is pretty fool proof. Advantage to doing it in manual the RPMs will hold as long as you want. |
#23 |
We are. I referred to whether it was bone stock or any one of a gazillion different builds.
2020 ZL1LE A10.
LME LT4 390 short block, LME CID Heads, Kong E2650, FBO. 15" conversion, MT ET Street R 325/15. 100 octane: 1045hp/1055tq. 100 octane + Meth (1x10+): 1117 hp/1067 tq |
#24 | |
![]() Drives: 2023 BMW M4 Competition Join Date: Dec 2012
Its the slower cars that typically go from a lower speed roll or dig on the street You can also do your own testing with a Dragy device to see what works best for practice https://www.google.com/search?q=Dragy+gps
2023 BMW M4 Competition (daily)
2022 ZLE M6 (weekend toy) 2022 BMW X3m40i Past: 2022 Tesla S Plaid 2020 Shelby GT500 sold 2019 Hellcat Redeye-traded for new GT500 2019 ZL1 A10 - sold (meh) 2019 Tesla M3P 2016 Hellcat Challenger - A8 sold but never forgotten 2016 Camaro 2SS M6 2014 Mustang GT A6 2012 Mustang GT M6 "brembo" 3.73/FBO 2012 Camaro SS L99 (Wife's)- slow Last edited by L99BEN; 01-24-2022 at 08:54 AM. |
#25 |
![]() Drives: 2018 ZL1 A10 Join Date: Nov 2020
Some people tend to shut down when youre about to drive around them and then say they won but in reality they wouldnt of. Make sure you agree on top speed shut down.
#26 | |
Black lightning
Thank god someone this!!
[ 2021 Camaro ZLE 10 speed
#27 |
![]() ![]() ![]() Drives: 2019 ZL1 Riverside Join Date: Apr 2020
Just put the car in track mode, it works perfectly fine
