Old 12-04-2021, 06:36 AM   #15
Firecaptain
Firecaptain's Avatar
Drives: '22 Summit White ZL1 A10
No.......but of course......anything can happen.......
Originally Posted by ZL1plumbin View Post
Oil pump still an issue on newer cars 20’ and up?
Firecaptain is offline   Reply With Quote
Old 12-04-2021, 06:53 AM   #16
hawk02
Coupe Newbie
hawk02's Avatar
Originally Posted by DangerZL1 View Post
Did GM change the pump design after 2018 to fix this problem?
GM switched the factory oil fill to 0W 40 for the 2019 MY LT1, LT4 and LT5 engines. If you think about it, the reports of failed oil pumps has been almost non-existent for cars built after the switch.
So yes, there was a significant change after 2018. Maybe not to the pump but to the weight of the oil.
Old 12-04-2021, 07:57 AM   #17
DangerZL1
Drives: 2023 Black ZL1 Auto
Thanks. I wouldn’t have suspected the oil viscosity and ESP formula would have been the fix.
Old 12-04-2021, 08:17 AM   #18
hawk02
Coupe Newbie
hawk02's Avatar
Obviously, I have no way of proving the change in viscosity fixed the problem. But it seems awfully coincidental that you don't hear much about pump failures for 2019 and up models. I could be wrong but I don't believe the part number for the pump has changed.
These engines hold 10 quarts of oil. And as someone else mentioned, some folks tend to beat on their cars before the oil is fully warmed up. The large volume of cold viscus oil was too much for some pumps to push around. Again, I'm just speculating. I have no proof the change in oil did anything. I'm just putting two and two together.
Old 12-04-2021, 08:36 AM   #19
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
I agree about romping on the engine or revving when the oil is cold too. Makes no sense to do that!
Old 12-04-2021, 10:43 AM   #20
Badmojo
aka BeastZL1
Badmojo's Avatar
I don't think the 0W-40 ESP switch is related to the oil pump failures, which appears to be a material defect in some pumps.
The development of 0W-40 ESP was originally due to the Corvette and was a hand-me-down to the Camaro. The additive package is meant to not foul catalytic converters.
2019 Camaro ZL1 1LE
Racing for ALS Youtube Link
Old 12-04-2021, 11:11 AM   #21
hawk02
Coupe Newbie
hawk02's Avatar
I get that. But why change viscosity? And especially after the engines had been in the cars for 3-4 model years already. Why not put the additive package in a 5W 30 oil?
I suppose you could argue the viscosity change was so the same oil could be used for the street and the track. However, I didn't hear many owners complaining about having to change their oil for track use. And the ZL1 1LE and '19 ZR1 still required different oil so it wasn't universal to all models.
You're probably right, the change in viscosity had nothing to do with the oil pump failures. But it seems an awfully strong coincidence. And besides, I always enjoy a good conspiracy theory.
Old 12-04-2021, 11:27 AM   #22
swisstyphoon
Former GM Technician
swisstyphoon's Avatar
Drives: 2018 ZL1 A10, 06 Silverado Duramax
I'm sure the oil viscosity has nothing to do with the oil pump failures. Here's what they say about the switch to 0W-40
2018 Camaro ZL1 A10
Rotofab Big Gulp, Nick Williams 103, Magnuson 2650, 9.17" (14%) lower, 90mm upper, Vengeance Racing Heads (LME) Cam Package (Cammotion Stage 1), Johnson Lifters, DSX dual intank pump, Lingenfelter high flow check valve, Motion Raceworks Flex Fuel adapter, LPE Big Bore Hpfp, XDI 30% Injectors, BBK shorty headers, Custom 2.75" down pipes, Gesi Gen2 high flow cats, MM catch can.
2006 Silverado Duramax Diesel
MPI Compound Turbo
40% over Injectors
Efi Live DSP5 Tuning
Follow me on Instagram: SwissZL1
swisstyphoon is offline   Reply With Quote
Old 12-04-2021, 01:43 PM   #23
ZX-10R
ZX-10R's Avatar
Drives: 2019 ZL1 Riverside
I don't think it's related either, cold viscosity and pour point for 0W-40 and 5W-30 are pretty close - "the "0" is more of a marketing gimmick
Katech told me they can't tell a difference in the '19 and up pump
ZX-10R is offline   Reply With Quote
Old 12-04-2021, 05:56 PM   #24
pauly1119
pauly1119's Avatar
Drives: 2018 ZLE
Ive been running 0W-40 from day one.
pauly1119 is offline   Reply With Quote
Old 12-04-2021, 09:42 PM   #25
LT4Greg
LT4Greg's Avatar
I use 5w30 in mine and have almost 22,000 miles and so far no issues. Keeping tabs on it anyway because my drivetrain warranty is up next April.
Old 12-05-2021, 07:15 AM   #26
hawk02
Coupe Newbie
hawk02's Avatar
My ZL1 was built in October of 2016 and I took delivery in November 2016 so it's from the first production run. I switched over to Mobile 1 ESP 0W 40 in May of 2018 as soon I heard about the factory fill change for 2019.
You can all call me crazy, but I noticed a subtle improvement in my car's performance immediately upon changing to the 0W 40 weight oil. My car had a bit more pep and smoother acceleration. Nothing night or day but it was significant enough to notice. I would have never thought a slight change in oil viscosity would make a difference in performance but it did.
I know this is going to sound crazy but the change to 0W 40 oil is one of best mods done to my car.
Old 12-05-2021, 07:20 AM   #27
6spdhyperblue
Drives: 2SS 1LE
US gasoline switched to a lower sulfur limit in 2018 and you can’t run dexos2 with high levels of sulfur…diesel or gasoline
Old 12-05-2021, 07:24 AM   #28
6spdhyperblue
Drives: 2SS 1LE
Maybe provided better stability in the cam phaser
