Old 10-01-2021, 09:09 PM   #15
Vigilante375
Drives: 2018 Camaro ZL1
Originally Posted by JonDaddy82 View Post
Safety wire? Commonly used in motorcycle road race applications.
Safety wire only works if the bolt has holes in it for the wire to go through.
A bolt tab washer will work if the bolts keep backing out.
They shouldn't but weird things happen. The anti seize helps the bolt go into the block and not damage the threads or the block since the block is aluminum, right?
Old 10-01-2021, 10:57 PM   #16
JonDaddy82
JonDaddy82's Avatar
Drives: 2018 ZL1 Coupe NFG M6
Indeed, that’s why we drill holes in the bolt heads
1989 Forumla 350 WS6 <- High School
2000 Trans Am Firehawk <- After High School
2017 Colorado Z71 <- Daily
2018 ZL1 M6 <- Not Daily
JonDaddy82 is offline   Reply With Quote
Old 10-02-2021, 02:37 AM   #17
SFV1LE
Drives: 2018 Hyper Blue ZL1 1LE
Safety wire works great but very difficult to install in header bolts (requires drilling bolt heads, complex wiring, high cost for a pro to do right), these do the same thing and are very easy to install:
Stage 8 locking fasteners:
https://www.stage8.com/
Once installed correctly they cannot loosen, they're mechanically locked and easy to remove.
SFV1LE is offline   Reply With Quote
Old 10-02-2021, 05:25 AM   #18
FoundNemo
Drives: 2019 ZL1
Arent those for header to head bolts, not for collectors? Not sure what the locking tab would lock against on the collector flange.
FoundNemo is offline   Reply With Quote
Old 10-02-2021, 09:59 AM   #19
Vigilante375
Complex wiring? Please. Get the right size safety wire, a pair of pliers (or your hands) then 2 bolts together in a direction so that the wire is actually tighten the bolts and you're good to go.
I work with soldiers that safety wire aircraft components and they don't take any special class for safety wiring. Just read the procedure and if it's not right or tight enough, you take it off and do it again.
I'd use tab washers. Easy to use to but a 1 time use.
Old 10-02-2021, 11:19 AM   #20
overdriv
overdriv's Avatar
Drives: 1969 Chevelle SS 2019 2SS Camaro
Originally Posted by Camaro1973 View Post
This is a ball flange connection with 2 bolts, there’s no gaskets.
Sorry, thought you were talking about the flange at the head.
Must be a lot of movement at the ball flange. Maybe a set of springs under the nuts like some of the oem said use.
overdriv is offline   Reply With Quote
Old 10-02-2021, 12:40 PM   #21
SFV1LE
There is an exhaust pipe adjacent to the bolt holes on the flange right? The tab would be set on the right side against this, so it cant turn left. The make different length tabs for different applications to reach pipes that may be a little further away.
Old 10-04-2021, 05:02 AM   #22
FoundNemo
Drives: 2019 ZL1
Got it. I will give that a shot
Old 10-22-2021, 07:44 AM   #23
FoundNemo
Drives: 2019 ZL1
Trying out some Nord Lock washers on the nut side collector flanges (i know.. cue jokes) and will see how that goes.
Old 10-22-2021, 07:49 AM   #24
harrington81
Drives: 2015 Camaro zl1
Why not try Stage 8 locking fasteners.
harrington81 is offline   Reply With Quote
Old 10-22-2021, 09:29 AM   #25
swisstyphoon
Former GM Technician
swisstyphoon's Avatar
Drives: 2018 ZL1 A10, 06 Silverado Duramax
Any lock washer will not work because of the heat. Same with the regular lock nuts. Try copper exhaust lock nuts!
2018 Camaro ZL1 A10
Rotofab Big Gulp, Nick Williams 103, Magnuson 2650, 9.17" (14%) lower, 90mm upper, Vengeance Racing Heads (LME) Cam Package (Cammotion Stage 1), Johnson Lifters, DSX dual intank pump, Lingenfelter high flow check valve, Motion Raceworks Flex Fuel adapter, LPE Big Bore Hpfp, XDI 30% Injectors, BBK shorty headers, Custom 2.75" down pipes, Gesi Gen2 high flow cats, MM catch can.
2006 Silverado Duramax Diesel
MPI Compound Turbo
40% over Injectors
Efi Live DSP5 Tuning
Follow me on Instagram: SwissZL1
swisstyphoon is online now   Reply With Quote
Old 10-22-2021, 11:16 AM   #26
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
They work fine. Mine have been on for months without any problems. I’m sure his issue is already fixed.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90
