#15 | |
![]() ![]() ![]() ![]() ![]() Drives: Grandad's C2 L89 Join Date: May 2017
I have a friend with a Hunter Hawk Eye in his shop. We barter services. Saves me a ton of money. I run 3Rs full time, car is not a DD. 2 sets of OEM wheels, I run cycled tires on street as well. I have had the luxury to experiment to find what works best for me. I'm on the rack before and after events. I've had best success replacing both sets of TTY bolts, every other alignment. That's fortunately my biggest cost (excluding tires). FWIW, he has a super accurate screw/bolt thread micrometer that generally shows unacceptable stretch before 3rd alignment. I'm looking into SPL arms, I'm thinking that greater rigidity and eccentric lock out should eliminate that issue. I digress, off topic. OP, 0 poke on both alignment settings.
2018 ZL1 1LE sw/PDR
#16 | |
![]() ![]() ![]() ![]() ![]() Drives: 2019 Camaro Z-28 Join Date: Jul 2010
OK I run SPL Toe Arms on the rear of my 2019 SS 1LE. With those I run -2.4 degrees REAR camber and -3.1 degrees FRONT camber (using Vorshlag camber plates on the front) With those settings I run the following tire/wheel combinations that DO NOT have tire poke at the top of the wheel well but DO push the wheels and tires out from their stock positions. APEX SM-10 ET25 19 x 10.5 wheels with MS 4S 305 30 19 tires for daily driving setup and APEX EC-7 ET27 18 x 11 wheels with MICHELIM S8M slicks 30 38 18 tires for track (HERE I increase front camber to -3.6 degree front camber using 5MM spacers with extended thread lug nuts to avoid running extended length wheels studs) Now I DID try to run -3.1 front camber on track as well and it also DID NOT have tire poke BUT the car handles better with -3.6 degrees front negative camber. The MOST important setting to promote even tire wear is TOE IN TOE OUT settings. You want that be almost neutral. I got 20K miles and about 10 track days out of my FIRST set of MS 4S tires and tire wear was even. Since then of course I got a track only wheel/tire setup as described earlier.
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 Last edited by sr71bb; 10-03-2021 at 09:00 AM. |
#17 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2018 Hot Red ZL1 Join Date: Nov 2010
Sent from my moto g(7) power using Tapatalk
#18 |
Limitless Imagination
Drives: 2018 ZL1 & 2022 Hayabusa Join Date: Dec 2016
Got to do some measuring now that I have an alignment. Pretty much spot on with needing 9mm front, rear would need 6-7mm to be flush. This is fender to the edge of wheel.
That being said, I'll probably err on the side of caution and go with 1mm shorter. It's definitely not alot, but I'd rather be a little more tucked than little more poked. Once they come in, longer studs tapped in and spacers installed I'll see how it looks with the 3mm rears and then test fit the 5mm to see which I like best. Will update with pics soon
2018 Camaro ZL1 - Black
- OEM Options: A10, Exposed Carbon, PVR, Nav, No Sunroof - Lightly Tinted GM Dark Tails, DD Side Markers, Morimoto 5000k, 100% LED - RotoFab Dry, Forgestar CF5V (ZLE Spec), Eibach Pro, AeroForce Interceptor, GT4 Tow Hook - Carbon Fiber (Satin): Radio, Shifter, Steering Wheel Controls, Shifter Top, AC Vents, Side Mirrors & Shark Fin 2022 Suzuki Hayabusa - Brilliant White Pearl & Shocker Yellow Wheels - +4 Arm, 240 OEM Wheel, Brock's CT (Ti) Exhaust, 1.25" drop, etc... |
#19 | |
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 |
#20 | |
I'm not sure I follow you with extended lug nuts vs extended studs for same purpose. If you're running a 5mm spacer with stock studs, regardless of the lug nut length used, there still is only going to be able xx length of threads remaining to use. I'm probably missing something here.
#21 | |
Lug Nuts
Well yeah you are missing something (LOL). An extended lug nut has a shoulder that actually goes THROUGH the lug nut hole in the wheel so it engages the threads BEFORE they exit to the outside of the lug nut hole. PIC below shows extended lug nut compared to standard lug nut. Both are Gorilla Locks.
#22 | |
#23 |
NO PROBLEM!!!
#24 |
Waiting on spacers to arrive, but wanted to update thread if anyone else is reading and curious to what it "should" take to get OEM wheels flush. Will follow with pictures when I spacers arrive and studs swapped.
12-13mm spacer front, 2-3mm spacer rear. Since I have 5mm/3mm spacers I did some testing visually before ordering. I liked 10mm front with a 3mm rear. It won't be quite flush, but felt I should err on side of caution for what I'm looking for. Now that it's been a few days since I ordered, I'm pretty sure it won't be enough, lol. BUT I'll have spare spacers on hand now so will swap the old 5mm in the rear and add the 3mm to the fronts. Will pull out my QuickJacks for all this swapping, I'll thank myself later, lol.
#25 |
Little update. Extended studs (very easy swap), MRR M017 wheels (23/43 offsets), 10mm front and 5mm rear spacers.
This is as flush as I can currently get without extended lugs or swapping in extended studs for rear. I tried 3mm on rear, but they appeared more inside fender than fronts. Will test out 15/10mm combo soon to see how I like it, if so I'll order some extended lugs as suggested so I can actually drive with them. I wish I could get a shorter version of them like other lug nut in picture, but doesn't look like Gorilla makes any.
#26 | |
Your car looks awesome.. Sent from my moto g(7) power using Tapatalk
#27 | |
End game is, in a sense, make my own version of a ZLE, visually. Adding a little ZLE aero to match future wheel poke with the 15/10 spacers. I just havent 100% committed (maybe 90%) that I will dig it enough I'll be glad I cut the slots in my bumper for the canards. Really would like cut tabs off and use 3M VHB to attach outside edge of canards to bumper, but don't know if it'll hold good at high speeds. Probably will test other spacer combos until I get the look I want. I'll post pictures in this thread as I test combos out.
#28 | |
