Old 10-21-2021, 01:35 PM   #15
cthulhucaller
Drives: 2022 1SS Team Joe and Becky
Originally Posted by m6-lt1 View Post
To answer your question I think a normal mechanic can fix this. That being said I would actually see if your insurance would cover it. This isn’t a normal mechanical failure. This is mechanical failure due to vandalism (not sure if animals breaking your car is technically vandalism but you know what I mean)
It may well be covered under a comprehensive claim. I'd think twice about doing that unless the cost is exorbitant, as the insurance company might be happy to get it back from you via premium increases over the next few years.
A full service mechanic shop should be able to perform that repair. Check around your area to see who is well trusted.
cthulhucaller is offline   Reply With Quote
Old 10-22-2021, 10:03 AM   #16
ctrlz
It sounds like TastyBake is pretty talented. If the animals did not chew the wires in the areas protected by the split plastic shielding, he will just have to worry about the terminations at the connectors. Usually the pins in the connectors can be extracted with jeweler's screwdrivers or the like. then you open them and recrimp or solder and heat shrink it. Yes, some bridge wires will be needed.
While this sounds like a lot of work and may be a pain in the butt working under the car, the alternative is trusting this to a mechanic who is going to want to pull the whole harness.
it is hard to see from the photos how bad this all is. But it sounds like he has a running car, so my guess is only a few wires. Check ebay for the oxygen sensor, which will come with a wire attached. You may need an O2 sensor socket. Amazon or ebay for that.
iat, maf, p0112, p0113, p0223
