#15 |
![]() Drives: 2019 Chevy Camaro ZL1 Join Date: Aug 2021
Seen too many whipple/maggie/procharged camaros here, wanna be different. Plus I’ve always wanted a Twin Turbo V8
#16 |
Which would you choose out of the two? And for both those Cams are they 32%+ fuel lobe? And if you don’t mind what do the cam specs stand for? (Sorry am definitely still green)
#17 |
Drives: '21 Wild Cherry ZL1 Join Date: Aug 2018
Either one of those would help easily reach your goals.
If it were me, running a stock-ish motor I’d go with the smaller of the 2. It really depends on how much manifold pressure you want to use, type of fuel, & where those turbos will make the power (efficiently) in their compressor map. Without seeing a map it’s hard to say, but I’d think something n a 67mm inducer would make it a tad easier to hit your power goal. Last edited by gtfoxy; 08-10-2021 at 06:23 PM. |
#18 |
You need to check out CSP and Nick's (freedom rocket) videos on his gen 6 hellion twin turbo build. Your going to spend a ton of money going that route and you won't have to fueling to to get the hp you want.Your going to need port Injection or the XDI pump plus a lot of relocations in your engine bay.
#19 | |
#20 | |
#21 | ||
Make no qualms, it’s an awesome build. Yet at the same time anyone not knowing the ins or outs of a pump gas turbo build would have next to zero understanding of the nuances that went into it. Little things that make a huge difference in a 416 strokes like that. Rod/stroke ratio, valve sizing, port flow rates & velocities, valve curtain & acceleration ramps, compressor & turbine side combination… the list goes on. Someone might look at it & say “Hey, I could do that with a stock LT4 motor with more boost & fuel/octane.” Which is true, to a point, but it goes a lot deeper than that. I’m not saying you can’t reach your goals. What I’m saying is it’s going to be a tad more complicated than slapping a dual 62mm kit on a stock LT4, even with port injection & making over 1K crank HP. Quote:
Add: Turbine combination playes a larger part in boost response. Wheel size & design, turbine housing A/R & design, Center section bearing usage, & as well as the exhaust system itself. It’s a system, through & through, each part relying on the other to do what it’s designed to do in a given application. Last edited by gtfoxy; 08-10-2021 at 07:09 PM. |
#22 | |
#23 |
![]() Drives: 2017 Camaro 1SS M6 Join Date: Jul 2017
I would personally go with the 224/230 115
#24 | |
From there you will see what’s possible, & not, with what you have to work with, budget wise, to reasonably achieve your goals. A wise man realizes his limitations & seeks out those wiser than himself & takes counsel along the way. |
#25 |
![]() ![]() ![]() ![]() ![]() Drives: 2019 ZL1 Join Date: Mar 2019
This is a very street friendly cam with -3 degrees of overlap. Honestly mine is 229/240 116 with 2.5 degrees of overlap and its perfectly fine and no stall needed.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
#26 | |
My list of purchases in order. 1. Cam & install with valve springs/rockers (Maybe shop install) I would like port heads since I am going in there anyways but I have no idea about the port specs and it changes everything else, which is what shied me away from doing the heads as I already don’t know cam specs. >@_@ > 2. Billet aluminum Procharger intake 3. NW 103mm TB 4. Hellion kit (Maybe 64mm or 67mm) 5. Full exhaust W/O Cats to maximize the turbos 6. Mighty mouse catchcan 7. Tuned for that current setup 8. Still deciding fueling route may stay DI, leaning more towards PORT tho. Ofc this is after what is left of my 25k budget. 9. All labor/wrenching time will be my dad, friends, and myself. Feel free to pitch in tips/advice, it all is appreciated this will be my first time doing this much work on a vehicle. |
#27 |
How to tell/know that specific cam is 32%+ fuel lobe? As I am only doing the cam for air/fueling reasons which the stock cam can’t provide enough.
#28 |
I must say I'm still bewildered why a person buys a Zl1 and gets rid of the PD blower to add twin or single turbos. I love turbos and probably the coolest to watch at the drag strip but why start out with a 65000 Zl1. Start out with a Camaro that's sometimes half the price. I know everyone will say its a forged motor, yes it is but the Camaro Lt1 is also forged except for the piston and its pretty cost effected to change those to forged drop ins. So instead of having 85,000 in a Camaro Zl1 you have 50 or 55k in a Camaro SS that's lighter in weight by a 100 lbs or so. Your just going to get killed on resale and the Zl1 is really holding its value right now as well is the Camaro SS. Believe me I know what it costs to build one of these Camaro's so I'm very familiar with the cost of changing the fuel systems, short blocks, heads etc. and what is required to make one go fast. Just my 2 cents which sometimes isn't worth anything.
