Old 05-26-2021, 06:21 PM   #15
L78toLT1
L78toLT1's Avatar
You should be fine with an extra 5 gallons on an SS. ZL1, you will need at least 10. With my mods, I can do four 20 minute sessions with an extra 10 gallons. I arrive at the track completely full up though.
Baby Blue
Old 05-26-2021, 07:11 PM   #16
TWG1
TWG1
Drives: 2019 Camaro ZLE
(7) gal every 30 min on track for me; trip ODO usually gives me ~3.7-4.2MPG. That’s basically on track for the 5gal/20min figures others have posted. Note the A10’s are slightly worse. Having had both, the A10 couldn’t do a full hour session on a single tank; M6 will make it with 1/8 or less remaining.
Disclaimer: running in the southern tracks most of the time, and it’s my firm belief these motors run rich when it’s hot as a way of keeping heat in check.
2019 ZLE M6
2019 ZL1 A10 (Sold)
1967 Jaguar XKE Series 1 Roadster
2021 F150 Powerboost (on order)
TWG1 is offline   Reply With Quote
Old 05-26-2021, 07:12 PM   #17
eimarshall
eimarshall's Avatar
Drives: 2018 SS 1LE Hyperblue
I get just shy of 1/4 tank per 20min session. I can run 4 sessions on a full tank, but the gas light will probably end my last session early. I got 6 sessions in with an extra 10 gallons a couple weeks ago. I probably could gotten another half a session in with what was left, but didn't want to push it(or get it pushed off the track!)
In other words, you'll probably be fine with an additional 5 gallons.
eimarshall is offline   Reply With Quote
Old 05-26-2021, 07:55 PM   #18
sr71bb
sr71bb's Avatar
Drives: 2019 Camaro Z-28
Originally Posted by BanOne View Post
So got my first track day in a couple weeks and was wondering how much extra has to bring, Will be running four 20 minute session on a 2 mile course in Palm beach, Was planning on taking an extra 5 gallons but was not sure if that would be enough.
Thanks
I would bring 10 gallons. I will average 5-25 minute track sessions per day and I drive the car VERY hard and as noted the A10 will use more fuel because generally you be taching 5500-6000 RPM in TRACK MODE in the corners. BUT...if you are running 93, the suggestion to leave after a track session to fill up is a great one. Problem is if you run the DRIVERS EDGE events, you will have to miss a classroom session to do so because of TIGHT scheduling which I HATE by the way!!
2019 SS 1LE BIG NA A10
Eagles Canyon Raceway 2.7 CCW Below
https://youtu.be/c9M5UHDftcA
4-15-23 at SCCA TT U1 Class
MEGA Thread on THIS car:
https://www.camaro6.com/forums/showthread.php?t=602092
Retired Cars BELOW:
1973 Camaro, 1969 Camaro, 1969 Camaro SS RS
2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10
sr71bb is offline   Reply With Quote
Old 05-26-2021, 07:58 PM   #19
sr71bb
sr71bb's Avatar
When I was running E85 tune on a SS1LE I was using between a Quarter to A Quarter and a HALF tank PER Session. E85 burns 30% faster than 93.
lol must be nice ive heard the zl1 1le guys use a quarter tank of gas each session or so
Retired Cars BELOW:
Old 05-26-2021, 08:03 PM   #20
UnknownJinX
UnknownJinX's Avatar
Drives: 19 Chevrolet Camaro 2SS 1LE Shock
My experience is that I would take 3/4 tank of gas on the gauge to a half-day open lapping event(3 20-minute sessions). Ended up with about 1/4 tank on the gauge after.
For a full day, I would try to start out with a full tank, but I will need gas if I were to use up all 6 sessions. As others mentioned, you can just get gas in between sessions or during lunch break.
Each track is different, though. If it's not anything competitive, just lean on the safe side and start with a full tank. I personally wouldn't run it below 1/4 tank on the gauge, definitely not 1/8 tank on the gauge just to avoid any potential fuel starvation. This is especially critical for boosted guys.
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock
GM Performance Intake and that's it, because driver mods before car mods
Past:
2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold)
2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled)
UnknownJinX is offline   Reply With Quote
Old 05-26-2021, 08:13 PM   #21
sr71bb
sr71bb's Avatar
I dont know about THAT, I learned this in MATH class in my Teenage years about 40 years ago and it STiLL holds up today:
MORE FUEL YOU BURN = MORE FUN YOU HAVE
Retired Cars BELOW:
Old 05-26-2021, 09:06 PM   #22
2010REDSS
2010REDSS's Avatar
Drives: 2018 ZL1 1LE
Very close to 1/2 tank in a 30min session at RA....
She eats 93, tires and brakes......but its quite a ride!
2018 ZL1 1LE "RAZECAR"
2016 2SS Convertible "NOTOPSS" (Sold)
2015 Z/28 #306 "ITZFAST"
2010 2SS Coupe "FASSTER" (Sold)
2002 SS/RS "02FASST" (Sold)
2007 Factory Five Racing GTM "REDBLUR" (Sold)
"There are two kinds of cars. Red....and everything else!"
2010REDSS is offline   Reply With Quote
Old 05-27-2021, 12:10 AM   #23
ICTsccaCamaro
I must drive like a ass on track, I am almost using a half tank per session with my ZL1 1LE. I will have like an 1/8 or 1/4 at best after 2 sessions. Luckily both of my local tracks have fuel pumps at the track in both 91 and 100 octane flavors.
ICTsccaCamaro is offline   Reply With Quote
Old 05-27-2021, 07:47 AM   #24
BanOne
Drives: 1977 Pontiac Trans Am
Originally Posted by Roostie View Post
What car and engine are you running? A '77 TransAm? Restomod car? It would be pretty hard for us to guess rate of consumption on a car like that.
3/4 of a tank is good for me all day... V6 is great that way.
For a V8 SS, a full tank plus an extra 5 gallon jug will probably get'r done.
Stock ZL1 1LE, I joined before I owned it so that is why the trans am is still the only car listed. Thanks for all the info. My plan was to arrive completely full in addition to the 5 gallons extra.
BanOne is offline   Reply With Quote
Old 05-27-2021, 08:06 AM   #25
TrackClub
TrackClub's Avatar
It all depends on a venue and how long one ends up at WOT. I usually bring 3x5+ gallon cans that fit perfectly side by each at the back of a trunk. But like I said: it depends.
Also, it depends if one has time to go off site to get gas, as some events run classes immediately following on track sessions, so the only spare time is lunch time. Cheers!
Old 05-27-2021, 02:10 PM   #26
ponyboy96
ponyboy96's Avatar
Drives: 2020 ZLE A10, 2018 F250 Diesel
Definitely this. I can get about 3 sessions starting on full before having to fill up. Expect to run about 1.5 tanks per day. Best to top off at the lunch break each day.
ponyboy96 is offline   Reply With Quote
Old 05-27-2021, 02:33 PM   #27
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
lol jesus im just a peasant 1ss with bolt ons
Old 05-29-2021, 09:40 AM   #28
BanOne
Thanks everyone for the responses, event is at PBIR in Florida so it is pretty isolated and because of vivid they are not doing lunch just running straight through. So sounds like I need 10 extra to be safe.
