| View Poll Results: What is your hot idle oil pressure in your ZL1 (LT4)? | |||
| less than 20 |
1 | 2.27% |
| 20-25 |
2 | 4.55% |
| 25-30 |
23 | 52.27% |
| 30-35 |
14 | 31.82% |
| 35+ |
4 | 9.09% |
| Voters: 44. You may not vote on this poll | |||
Thread Tools |
#15 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro ZL1 Coupe Join Date: May 2016
#16 |
![]() ![]() ![]() ![]() Drives: 2018 ZLE Join Date: Feb 2018
My car is built 6/18 and is usually right at 30 or just slightly above at idle after the temp comes up. I have changed the oil a stupid amount of times already at only 4800 miles. I have changed it 4 times and the dealer did the first one at 500. I use 0W-40 ESP Formula. I know its a waste but its therapy for me.
#17 |
I run 5w30 in mine!
#18 |
![]() Drives: 2017 ZL1 Join Date: Apr 2020
Autos will always be a few lbs less in my experience
2017 ZL1 M6 Silver Ice Metallic
#19 |
On the gauge, around 36-38
2020 ZL1LE A10.
LME LT4 390 short block, LME CID Heads, Kong E2650, FBO. 15" conversion, MT ET Street R 325/15. 100 octane: 1045hp/1055tq. 100 octane + Meth (1x10+): 1117 hp/1067 tq |
#20 |
![]() ![]() Drives: 18 zl1 Join Date: Aug 2017
hot idle, it's just a hair under the 30 notch. cruising at around 70 mph, 1600-1700 rpm, no load, I'm a little lower than 40, but I would say past 35
#21 |
![]() Drives: Canadian 2019 BLACK ZL1 Join Date: Feb 2020
#22 |
Petro-sexual
I only add this to try to put your mind at ease (even though I know I would feel exactly the same as you if I were in your shoes), but I recall reading (decades ago) that you only need a few pounds of oil pressure at idle. You "only" need enough to float the crank and the rest of the reciprocating assembly. While I'm sure that's all that's needed to float the moving parts at idle, seeing it drop the way you have, and seeing the experiences of many drivers is concerning. It is my understanding that when the LT1 first came out, I recall reading manufacturers are moving toward to these multi-stage-type pumps to increase fuel economy. You don't need 60-psi of oil pressure at idle. So now they move to the kinds of pumps we have now. And - now you have the kinds of problems many have/are facing now.
#23 |
![]() Drives: 2018 ZL1 1LE White Join Date: Jun 2017
Mine idles right at 30. 40+ when I start to move. Only 2300 miles.
#24 |
![]() Drives: 2017 Summit White ZL1 M6 Join Date: May 2017
My 17 idles just to the right of 30 lbs hot. Runs 40+ 2500-3000 range. 5/17 build date 15400 miles. 0W40 ESP oil.
Roto Fab/ Kook's LT's,ported blower,removed lid baffle/ 103mm TB' lower pulley and tune.
651/660. Last edited by ssrallyred; 05-25-2021 at 01:56 PM. Reason: add to post |
#25 | |
![]() ![]() ![]() ![]() Drives: 2018 Hyper Blue ZL1 1LE Join Date: Dec 2018
So IMHO with a C6 ZL1, if you're seeing hot idle pressure readings near or below 20 psi on the dash gauge during street driving on a warm day, you may have a problem that can become very serious. Knowing that parts like crank and big end bearings are still being lubricated at 10-20 PSI would be little comfort to me. My idle pressure always stays between 25-30 as far as I know. |
#26 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 Challenger Hellcat, 2018 ZL1LE Join Date: Dec 2009
Now I need to check the pressure on my 2018 at idle.
Jesus !!!!! Another thing to look out for !!!!
2018 ZL1 1LE/Red hot 2019 Shellby GT 350R/ Oxford white/ Matte Black Stripes/ Carbon Fiber Dash/ Electronics Package #413 |
#27 |
![]() Drives: '18 ZL1 1LE Join Date: May 2020
Mine is always 28-29 psi at idle. I just passed 26k miles.
2018 ZL1 1LE - Summit White, PDR, Rotofab CAI, 95mm TB, CSP 2" catless LT's, JMS Voltage Booster, AEM X-series WB, DSX flex fuel sensor, Banks Data Monster, Tuned by Ted Jannetty, 5% Tint, Blackvue DR900S-2CH, Diode Dynamics lighting, IGL Kenzo ceramic coating
#28 | |
That thing can do under 7 minutes on the Nurburgring. If you watch the 7:16 ZLE lap on the Ring you know how insanely fast that was (4 wheels airborne at 140+ MPH), no need in my lifetime for a car that is over 16 seconds faster, I would grow old and die driving a 992 GT3. GT3 will also cost less to run on track in terms of tires, brake pads, fuel etc. And with dry sump and Porsche engineering, it will run all day in 100 degrees with no overheat. If the motor has a design issue like the 991 GT3, they'll replace the motor. GM says "if your oil pump fails, here's a new pump--no we don't care if metal fragments spread through your motor" |
