Old 05-14-2021, 11:19 AM   #15
19 2SS
Drives: 2019 camaro 2ss
Originally Posted by JANNETTYRACING View Post
I do like our 95mm conversion kit moving from the 87mm on any 6th gen N/A or SC so Yes.
The big gulp will net you nothing at this power level.
I am sure there is more to be had in the tuning Your combo should easily make 600-625 RWHP on 93 octane
Ted.
When you say the big gulp will net me nothing, are you aware that im currently running the stock intake, not even a standard rotofab?
I talked to the guys at CSP yesterday who did my car, and they said that I was at the end of my fuel system when the car made 557whp, is that even possible?
2.9 Whipple, CSP longtubes, borla atak, lt4 fueling, dsx aux pump, big gulp, nw 103mm, zl1 rep wheels, Toyo r888r
19 2SS is offline   Reply With Quote
Old 05-14-2021, 02:39 PM   #16
wnta1ss
Drives: 2017 Camaro 1SS
Yes it is absolutely possible. I had a base supercharger (ECS/Paxton) on my SS with stock engine, stock exhaust, and no methanol injection. Low pressure fuel pump was upgraded to ZL1, but the hpfp and injectors were still stock LT1 at that point. My stock high pressure pump was not keeping up, and the rail pressure dropped in the upper end (centrifugal blower so they only make full boost at the top end). And this kit was the lowest-boost one that was meant for a stock LT1.
Procharger guy told us a while back that not every car can make the same power on it's stock fuel system, my experience and yours obviously support this over the blanket claims. Yes I am saying that if CSP tells you that your fuel is maxed, then I think that you should believe them.
Old 05-14-2021, 03:03 PM   #17
19 2SS
Yea but in my situation I have the zl1 hpfp so that’s why I’m confused as to how I could be out of fuel
Old 05-14-2021, 05:29 PM   #18
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Do you have the entire LT4 fuel system hight to low(Injectors, HPFP, LPFP)?
Old 05-14-2021, 05:53 PM   #19
19 2SS
I have the hpfp
Old 05-14-2021, 07:17 PM   #20
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
I have the hpfp
The LPFP usually runs out first and needs a voltage booster, stat. Then, the HPFP runs out not far behind. Can’t remember off hand when the LT1 injectors drop off but you should have changed them when you did the HPFP, IMO.
Do you have data from CSP? Otherwise we’re guessing. Need to know:
1. Low side pressure
2. High side pressure
3. Injector pulse width
Old 05-15-2021, 06:22 AM   #21
wnta1ss
Sorry, I did not notice your sig about the LT4. But, if you only have the hpfp changed, perhaps your low side pump is falling? You could ask CSP what you need to fix before pushing it further.
Old 05-15-2021, 08:17 AM   #22
JANNETTYRACING
JANNETTYRACING's Avatar
No I was comparing standard rotofab to big gulp at your power level.
You can certainly benefit from a Standard rotofab and 95 mm tb.
https://jannettyracing.com/products/...-including-z06
If you add a JMS fuel system voltage booster your fuel system will support 580 RWHP but that's it.
I recommend adding our LT1 fuel system upgrade package which includes the JMS
https://jannettyracing.com/products/...2018-camaro-ss
www.jannettyracing.com
email tedj@jannettyracing.com
Old 05-15-2021, 10:12 AM   #23
KingLT1
KingLT1's Avatar
I have the hpfp
That is your issue...you need the entire LT4 fuel system high to low. Just changing the HPFP gained you very little.
Old 05-15-2021, 03:11 PM   #24
19 2SS
I knew I should've told them to do the whole thing, I wonder why they only suggested the high side.. and the blower has to come off for this doesnt it?
Old 05-15-2021, 09:01 PM   #25
Joshinator99
Moderator
Doing the HPFP and not the injectors does not make much sense IMO. The LT4 HPFP runs a higher pressure that the LT1 injectors are not supposed to run. Complete mismatch IMO. Maybe someone knows something else that I’m missing?
Old 05-20-2021, 01:08 PM   #26
19 2SS
I’m being told that my best option is a better cam, and that the high side is the one that’s running out
Old 05-20-2021, 05:33 PM   #27
Joshinator99
Moderator
See my post above. Stock LT1 low side is weakest link. But your high side is a mess too, running LT4 HPFP and LT1 injectors that need lower pressures than what the LT4 HPFP wants to put out.
LT4 in tank with JMS
LT4 HPFP with cam
LT4 injectors
That combo will get you in the right direction to make power with a blower.
Old 05-20-2021, 06:19 PM   #28
19 2SS
LT4 HPFP with cam
LT4 injectors
I agree this makes a lot more sense, in the same breath I have trust in what the guys at CSP are saying but they could be mistaken who knows..
He’s what they’re saying.
Me: I meant like do you think I’m running out at this level because I only have the high side done? No injectors/low side
Them: No, that is what was running out, not the low side or injectors. They are independent, If the low side was dropping that can cause the high side to run out but the low side was holding steady
