Old 04-12-2022, 09:59 AM   #15
WillyZ83
WillyZ83's Avatar
Drives: 18 zl1 garnet red
beautiful build man! Loving how it came together
IG - @zl1_will
2022 zl1 740hp / 730tq stolen
2018 zl1 Maggie - 2" headers - flex fuel - lowside fuel ssytem - +30 injectors - cordes ice tank - spl rear linkage arms
WillyZ83 is offline   Reply With Quote
Old 04-13-2022, 07:58 AM   #16
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
Originally Posted by James Montigny View Post
Follow-up on the project.
The 2650 is finally in along with a +32% cam and TSP stage 2 heads.
Fuel is supported with LT4 HPFP and injectors along with the DSX low side and flex sensor.
I sold the 95mm LT5 and used a 103mm Katech instead.
We went with TSP LTs and a big gulp to keep air flowing.
With the provided 110mm pulley, it put down 670 through an A8 at 6psi.
I'd like to circle back once everything is broken in and bump that up to 10.
It has good street manners and surprisingly nice fuel economy on the highway. But I do want to add a pair of resonators to take care of the rasp at 1700rpm (ie: part-throttle acceleration, where it is most annoying). It's not likely to see the track or any formal street racing, but it does put a smile on my face I'm very happy with the way this turned out.
Attachment 1096603
blk TB or Green TB would be killer!
Old 04-13-2022, 08:36 AM   #17
James Montigny
James Montigny's Avatar
Drives: 2017 Camaro 2SS
Good idea.
James Montigny
2017 Camaro 2SS A8 - Krypton Green
Magnuson 2650 @ 13psi, Forged TSP Rods/Pistons, TSP Ported Heads, BTR PD Cam, Aeromotive Low Side, DSX Flex, LT4 HPFP, 103mm TB, Big Gulp, Meth.
Built by Killer Performance, Tuned by Justune.
James Montigny is offline   Reply With Quote
Old 04-21-2022, 01:31 PM   #18
James Montigny
Mine also has a drone in the 1750-2200 range, so I've gotten into the habit of downshifting one gear and avoiding that range. There's a lot of posts here about failed efforts to eliminate this drone with mufflers and resonators.
I added the Borla 60608 resonator today. it made a huge difference in how smooth the car sounds and it's a lot more fun to drive now without the rasp.
We went ahead and deleted the AFM valves and crush pipes while we had it on the rack.
James Montigny
Old 04-23-2022, 09:31 AM   #19
laynlo15
Drives: 2022 Lt1 A10
Looks good, make sure you put the passenger floor cover back on. It does help it stay quieter in the cabin. I actually added them to my LT1 since it was so loud inside.
Old 04-23-2022, 10:26 PM   #20
James Montigny
Yes, it has been ordered. It got caught on debris on the interstate one night and I had to tear it off so I could get the car home.
James Montigny
Old 04-24-2022, 09:04 AM   #21
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Nice setup. Some spray detailer on the cowl area might get ya another 15whp.
Old 04-24-2022, 10:24 PM   #22
James Montigny
LOL It did get a good detail after the work was done to take care of a few weeks of dust :p
https://www.instagram.com/p/CcGiCglJlGK/
(and yes, the cracked bumper is getting replaced)
James Montigny
Old 02-12-2024, 10:34 AM   #23
James Montigny
Killer Performance did a great job on your build. I'm guessing when you step up to 10 psi you'll be about 730 to 740. Are you going to be at the Street Car Takeover Kickoff this Saturday?
Is the limitation here injector, or something else?
I have it in this week because I had two lifters fail.
I asked Justin to go ahead and upgrade to forged pistons while the block is out for repair anyway, even if only for peace of mind.
We can finally get the bumper, meth kit, 103mm snout and pulley done as well.
I feel like +30 injectors might not be a terrible idea at this stage if the fuel rail can handle the volume.
James Montigny
Old 02-12-2024, 01:09 PM   #24
Katech_Mike
Drives: 2015 Camaro ZL1
It looks like you already have a low side and LT4 HPFP.
If that's the case than yes the injectors are next.
Katech_Mike is offline   Reply With Quote
