Old 04-25-2021, 08:21 AM   #15
D3adch1ld
Drives: 2019 Camaro ZL1 1LE
In addition, if you are running just an intake and a tune, don't change the plugs, you dont need them yet.
Sent from my SM-N986U1 using Tapatalk
D3adch1ld is offline   Reply With Quote
Old 04-25-2021, 08:36 AM   #16
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Originally Posted by D3adch1ld View Post
The LT4 uses 6 range (one step colder than ss), with my round of bolt on stuff, I did NGK LTR7IX-11, the first thing I was told to change by Vengeance before tunning... something I did notice is that these cars pull timing even in factory form unless running a boost additive. The new plugs just compensated for the additional heat in the cylinder, without them, I probably would be pulling even more timing. Should be noted, they also come pregapped about the same as factory specs which is what really matters to prevent fouling, they get plenty of heat the stay clean and a nice large gap to burn as much fuel as possible without any blowout what so ever.
If you want to run more timing, E50 did the trick for me.... I have a very happy fuel system 2900 psi at the rail, 80psi low side, inj around 5.4ms, and 23° of timing at wot every single time.
Old 04-25-2021, 08:51 AM   #17
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Bolt-on car on E85 is fine running stock plugs. Normally don't go colder unless you do Heads/Cam or a power adder.
Old 04-25-2021, 09:00 AM   #18
D3adch1ld
Yes sir. I'm LT4 and had to be done.
Old 04-25-2021, 09:26 AM   #19
KingLT1
KingLT1's Avatar
Understood...I too run a LTR7IX but I am FI similar to you and it's even more critical that I run a colder plug since the LT1 has a lot more compression then a LT4.
Old 04-25-2021, 09:57 AM   #20
D3adch1ld
Absolutely, you are more of a candidate to the colder plug than myself for sure. Btw, I've seen your tuning thread as well. Any chances you have done a secondary XDI HPFP tune at some point? Trying to get the base changes to properly run the system
