Old 04-13-2025, 12:07 PM   #15
Baddawg53
Drives: 17 hyper blue 2SS M6
Originally Posted by LiqTenExp View Post
Sent you a PM on my process that solved everything
I'd love to hear what you did to end up fixing the issue. If you don't mind drop me that PM also? I don't really have a lag that I can tell of in my M6 car but I'd love to compare and data log mine to see if I'm seeing anything I might just be used to in the car.
Baddawg53 is offline   Reply With Quote
Old 06-17-2025, 09:03 PM   #16
bowtie_thunder
Camaro Connoisseur
bowtie_thunder's Avatar
Drives: Red Hot 2020 Chevrolet Camaro 2SS
Actually, yeah I’d really like to hear this as well—as I too believe I have min spark base table issues related to torque management pulling timing at WOT and also on decel. I know it would be a bit different considering I have an A10, but I really need to solve this problem by month’s end. Any help would be greatly appreciated!
EDIT: forgot to mention, I’m running the following mods:
-6.2L GMPP CAI
-95mm LT5 Throttle Body
-Flex Fuel Sensor (currently at E80 on LT1 FS; pending LT4 install)
2018 Camaro SS Vert, A8, Non-MRC Hacked & Stolen; R.I.P.
Current: 2020 2SS Camaro, A10, Non-MRC
PLM Axlebacks | GMPP CAI | GM Flex Fuel Sensor w/Gen 5 DIY Harness | Full LT4 FS | LT5 TB | 530 WHP on E81
bowtie_thunder is offline   Reply With Quote
Old 09-13-2025, 08:57 AM   #17
nissandr
Drives: 22 camaro 1le rapid blue
Originally Posted by J.A.Black View Post
IDK if you're still around but I've been trying to figure this out for a while and this thread is the closest thing to what I've been experiencing. No one seems to know what I'm talking about when I describe the problem. It only occurs when I have Rev match enabled, but immediately after an up shift (manual car like yours) there's a severe delay in torque delivery, like my throttle won't open for the first second or 2, then it opens and I accelerate. From reading this thread it seems like this is what you're describing as well. Can you post exactly what you did to get around this? It sounds like you made some good progress but this last post implies there were more changes you were gonna try.
I think I have the same issues mines procharged and seems to lose power under acceleration then after a few seconds feels like you’ve been hit in the rear and it takes off. Throttle response is lacking also
nissandr is offline   Reply With Quote
Old 11-08-2025, 08:40 AM   #18
Enslaved
Drives: Camaro SS 1LE
Can you share?
Enslaved is offline   Reply With Quote
Old 11-10-2025, 07:35 AM   #19
18.2SS.1LE
18.2SS.1LE's Avatar
Drives: Chevrolet Camaro
I had the same issue as both of you, Ryan Stevens at GPI got it figured out pretty quickly.
Procharger P1X, CSP Big Boy Cam, CSP Headers, LT5 Throttle Body, MSD Intake, LT4 HPFP, LT4 Injectors, JMS BAP, 93 + Boostane - 750+WHP
18.2SS.1LE is offline   Reply With Quote
Old 11-27-2025, 11:24 AM   #20
Enslaved
Can you share what was changed? The general consensus seems to be that there are hidden/user defined tables that are not accessible on the 1LE models specifically. I know outright removing all TCS/trq limiting capability from the OS is a way to do it, but that is silly on a car meant for fast and consistent track times.
I'm still quite new in this community - Is Mr. Stevens the type that would share this information? Or is this one of those pay to play scenarios
