Old 03-30-2021, 11:50 AM   #15
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
Originally Posted by ZX-10R View Post
That's why I said with good air flow, and yes an air to water IC will get 20 F above ambient. Do the research.
Only way I’m Going under 90F is when it’s 45 degrees or less outside. I think lowest I’ve seen my mat temps were like 85F.
Warm days like 80F cruising could be 125F. Soon as you get into a pull, or just even a bit of boost though it will drop some. It can go from 125 to 115 quickly.
Sitting idle. Of course temps can get to 150f. Soon as car starts moving though , even just a few mph temps drop drastically.
This isn’t the case on the stock blower, which is pretty much what we’re all discussing. Once that stock blower is hot and air entering is warm, the blower really takes forever to cool Down, if it even does.
The benefit of the 2650 is you simply don’t have this heat soak. As long as your moving, mat temps will always be good. Of course unless it’s very hot ambient temps then of course physics come into play.
Old 03-30-2021, 12:31 PM   #16
ZX-10R
ZX-10R's Avatar
Drives: 2019 ZL1 Riverside
Originally Posted by Camaro1973 View Post
Once that stock blower is hot and air entering is warm, the blower really takes forever to cool down, if it even does.
Which is a huge liability on the track (esp roadcourse, drag as well), think how much power you're losing (plus relatively low boost). No wonder dyno numbers on these cars (stock) are all over the place, from 520 to almost 600 rwhp
ZX-10R is offline   Reply With Quote
Old 03-30-2021, 02:14 PM   #17
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
540-560 on dynojets are what they typically all run.
Old 03-30-2021, 02:16 PM   #18
JSH
JSH's Avatar
Drives: '20 ZLE
Sort of related to this, my engine will have the FII blanket and spacers in a few weeks, so we'll see about its temps
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 03-30-2021, 02:18 PM   #19
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
Nothing will save that stock blower unless you got an ice tank
Old 03-30-2021, 03:00 PM   #20
JSH
JSH's Avatar
Drives: '20 ZLE
If the ported SC doesn't work, I'll do the smaller maggie
2020 ZL1LE A10.
Old 03-30-2021, 05:56 PM   #21
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
The smaller maggie is marginally better. Hence why it came off for the 2650.
Old 03-30-2021, 05:58 PM   #22
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
aww don't hate on my 2300, it is definitely better Plus there was no such thing as a 2650 when I bought mine :(
Old 03-30-2021, 06:01 PM   #23
DrBlockHed
Drives: 18 ZL1 Convertible
Looking forward to seeing your results!
DrBlockHed is offline   Reply With Quote
Old 03-30-2021, 06:09 PM   #24
KingLT1
KingLT1's Avatar
I just posted the results from a 2650 on my Brothers C7Z and it has the Cordes expansion tank. 35-40 degree day cruising down the highway at 50+ mph MAT are still 90+. Now the ZL1 does have better air flow but you still are not getting down to 20 degrees over ambient. Either way it doesn't matter like I already said previously. The benefits of the 2650 is that it doesn't heat up on a hard pull like the smaller blower and it cools back down faster.
Not hating at all...It is better but it still ran hot on a H/C car with a 80mm pulley. The 2650 was the way to go for this particular setup. On a bolt-on car it would work great.
Old 03-30-2021, 06:09 PM   #25
ZX-10R
ZX-10R's Avatar
740 rwhp hp on 93 pump gas, Stage 1 bolts on only. Note Elite catch can
Old 03-30-2021, 06:22 PM   #26
JSH
JSH's Avatar
Drives: '20 ZLE
Or a Whipple or Procharger or other that can get me to around 800 wheel on 93 and maybe, what, 820 on 104u/l
2020 ZL1LE A10.
Old 03-30-2021, 06:59 PM   #27
Z OH 6
Drives: 2024 CT5-V Blackwing
This thread has one shill posting about two products they endorse all over this forum. I'll let everyone figure out who it is.
Old 03-30-2021, 07:06 PM   #28
ZX-10R
ZX-10R's Avatar
What's your problem? Get a life and quit stalking me, it gets old
