#15 |
![]() Drives: 2017 SS 1LE Join Date: Mar 2017
Yes, ran majority of the wiring today, should finish Sunday. Taking time as I modified the disabled noise tube to get o2 lead into the car and make it look factory.
#16 |
Best spot for switched power under the dash (search not working on the kindle)...
#17 |
![]() Drives: 2018 Chevrolet Camaro 2SS 1LE 6M Join Date: Jul 2019
I ran a wire from the fuse box in the trunk. Could not find a decent switched power source under the dash. Some people are using the accessory plug in the center console.
Bolt-ons.
#18 |
Thx. I did that for my coolshirt, off the power for seat fan (not used in 1LE), will check to see if it can take both loads, coolshirt pump is very low 5amp
#19 |
Ok, installed. Appears to be working reads 14.6 to 14.7 idling. Rev it it hard and goes to 20, but assume that is the fuel cut off safety net when in neutral..
Button up the wiring and log this puppy and see how it runs... And get any tweaks done... |
#20 |
Ok stuck, I can add the new channel, but two seconds after I start scanning it goes away, thoughts? HP tuners sees AEM x series and I grab wb eq ratio 1.
#21 |
Dumb Ass Deluxe
Drives: A Tricked Out Mountain Bike Join Date: Jun 2019
So, I've been searching and can't find anything conclusive, which means it probably doesn't exist.
Is there any way to put a wide band in place of a standard 02 and pick up the signal in the OBD2 plug thru CAN? The 30-0334 looks like it's a stand alone unit that runs the signal down to the OBD2 pass thru connector. I'd prefer not to have a gauge in the car that doesn't really get used (other than when you're tuning) and just be able to plug in to check it when I need/want to.
#22 | |
![]() ![]() Drives: 2018 HBM ZLE Join Date: Aug 2017
Now if you have catless headers, you can run your wideband sensor in the secondary o2 bung. Works perfect |
#23 | |
Dumb Ass Deluxe
![]() I was hoping that I could just read a wideband O2 off the logger plugged into the obd2 port instead of having to install the whole enchilada. Your idea sounds like the next best option. THANKS!
#24 |
Drives: 21 ZL1 Join Date: Feb 2022
So do you need to use the gauge? I dont want it in the inside of the car. Just need the WB to be able to datalog for my tuner/remote tuning.
Can I leave the gauge off and just tie up the wires? |
#25 |
If I remember correctly, the wire from the sensor goes to the gauge, then to the obd2 plug. So not sure exactly how that would work, but I would think someone has figured it out
