Old 01-24-2021, 10:43 AM   #15
ZX-10R
ZX-10R's Avatar
Drives: 2019 ZL1 Riverside
Never had a problem jacking up this car quickly using jack pads from Amazon, piece of cake yet there are never ending threads about how it's rocket science and someone always has to show off their lift
ZX-10R is offline   Reply With Quote
Old 01-24-2021, 10:54 AM   #16
NiteBlitz
Drives: Camaro ZL1
exactly why I came on here and asked. Had a headache from all of the results I found.
NiteBlitz is offline   Reply With Quote
Old 01-24-2021, 10:59 AM   #17
puppykat33
puppykat33's Avatar
Drives: Black 2019 ZL1 M6,
dude you are always so negative when people ask questions! whether it be oil or anything else. Why does it provoke you to be so negative in your replies. If answering questions bothers you so much maybe you should stay off the forum or not comment if you cant be constructive. No reason to be an asshat just answer the question or dont
2019 Black ZL1, M6, CF Hood and Dash, Nav System, ZL1 Addons rock guards and lift points, Michelin Pilot Sport 4S, DD Smoked Marker Lights, Ceramic window tint, Gtechniq 9yr ceramic coating. JL Audio stealth box 12W6, Dyanamat trunk, Dead pedal cover, Soler TB/TC, Green Filter, Carbon-fiber Borla S-Type
puppykat33 is offline   Reply With Quote
Old 01-24-2021, 11:06 AM   #18
CW3SF
CW3SF's Avatar
Drives: 2019 Chevy Camaro ZL1 M6
The whole purpose of forums is to share information and gather to discuss common interests. Some people are just incapable of recognizing where they are and what’s going on around them. I’ll keep sharing what I have to offer and I don’t care who doesn’t like it.
CW3SF is offline   Reply With Quote
Old 01-24-2021, 11:09 AM   #19
puppykat33
puppykat33's Avatar
Yea Chief
ZX-10 always has something snarky to say
Old 01-24-2021, 01:32 PM   #20
az4783054
Drives: SWXXZL1
IGNORE feature works for me. It's his loss if no one pays attention to him.
"Joe" does a hilarious impression of a slinky toy on stairs.
az4783054 is offline   Reply With Quote
Old 01-24-2021, 01:51 PM   #21
ZX-10R
ZX-10R's Avatar
I'm not trying to be "negative" but it's straightforward - cutouts under the car show you where to place jackstands, use jack pads to protect the pinch welds e.g. https://www.camaro6.com/forums/showp...64&postcount=6
Old 01-25-2021, 09:24 AM   #22
ste1n
Drives: 2019 2SS
When placing jack stands under pinch welds do you use anything to protect pinch welds? I already have 4 ZL1 addons lift points installed for jacking the car up but I am still not sure where to place jack stands.
ste1n is offline   Reply With Quote
Old 01-25-2021, 09:45 AM   #23
ZX-10R
ZX-10R's Avatar
No I just position the jack stand arm to avoid the pinch weld. The problem is when you take these cars to tire shops they don't care and pinch welds inevitably get a few bends
Old 01-25-2021, 10:29 AM   #24
Jaxcam02
Jaxcam02's Avatar
Drives: 2017 Silverado/2017 ZL1
I bought some ESCO flat top jack stands so I can jack from the front or rear of car and use the jack pads on the flat top stands.
Pasted a link to the image, image size was way too large for the forum.
https://images-na.ssl-images-amazon....AC_SL1500_.jpg
Jaxcam02 is offline   Reply With Quote
Old 01-25-2021, 09:23 PM   #25
sengli
sengli's Avatar
Drives: 2015commemorative vert 2SS
On the four post I have, I bought the accessory trolley jack (in front of car) that rides in the inside grooves of the lift lands. I can lift both sides or one side with this extra hydraulic jack assembly that has extendable arms that reach out to grab under body lift points. So swapping tires, brake pads etc is very possible. Plus my lift is portable, and I have the wheel kit as well.
But yes it is also used to just park things on if I wish.
2018 ZL1 Bright Yellow, A10, PDR, sunroof, carbon hood, and dash- sold
2020 2SS A10 sunroof..shock and steel special-traded
2015 commemorative vert 2ss
sengli is offline   Reply With Quote
Old 01-26-2021, 03:33 AM   #26
Bangkok_ZL1
Flying around Thailand
Bangkok_ZL1's Avatar
Drives: 2019 Camaro ZL1
You can easily change tires on a 4 post lift. I do it all the time on mine. I have a Jack that slides down the center track of the lift and has arms that are adjustable inside to outside. I can lift either the whole front end or the whole rear end off the car off the wheel paths. I also have a Jack tray that I can use and raise all 4 wheels off the lift at the same time.
It’s not just an extra parking space.
Nice..... I didn't think of that. Actually, the 2 post lift is what is selling for only a grand here. so I'll get that, But I like the 4 post and your floor piece to lift the front or rear is brilliant.
Bangkok_ZL1 is offline   Reply With Quote
Old 01-26-2021, 03:35 AM   #27
Bangkok_ZL1
That's why you buy ZL1 addons lift pads... They saved my ass. Thanks ZL1 Forum members for recommending. You all saved my and my car FOR SURE.
Old 01-26-2021, 03:50 AM   #28
Bangkok_ZL1
You know, I have seen jack stands rubber adapters. If I wasn't buying my own lift, I'd buy these rubber adapters along with my stands. Those AddOn lift pads were a life saver for me though. Can't rave about them enough. I saw it in action, when these Thai mechanics would have really messed up my car. I'm so lucky to have listened to the forum members that suggested these. I can't thank them enough, really. But they did forget to tell me to be careful and go very slowly over steep speed bumps (slightly touched the lift pad once)....
