Old 01-20-2021, 06:45 PM   #15
2018ZL1
2018ZL1's Avatar
Drives: 2018 ZL1 A10 NFG 2019 COPO 350 SC
Originally Posted by sickss228 View Post
My WELD S77 beadlocks and M/T ET street R's came in today. Spent the afternoon mounting them up and checking the fitment. Everything fit perfect. They are 17x10's w/ 7.2 backspacing, high pad and a 5x120mm bolt pattern. The tires are 305/45-17's
They look killer!! You are gonna be happy with the way those tires hook!!!
2019 COPO #32
350 SC
8.25 167MPH
2018 ZL1-NFG-A10
388CI L8T
9.32 147MPH
2018ZL1 is offline   Reply With Quote
Old 01-21-2021, 05:05 PM   #16
sickss228
Drives: 18 ZL1 mostly stock
I hope so! I copied from your build and went with the 30% FIC injectors, I got a great price on them so I figured it couldnt hurt and it will hopefully let me run E60.
07 LMB Z06 Cartek 4x heads and cam, ARH, Vararam, FAST 102, NW 102
18 ZL1 M6 MTI cam, FED heads, FBO's
sickss228 is offline   Reply With Quote
Old 01-21-2021, 05:25 PM   #17
Scottyz
2019 ZL1 1LE MY GOON
Scottyz's Avatar
Drives: 1980 Z28 Big Red.
Those are sweet
Old 01-22-2021, 06:54 AM   #18
2018ZL1
2018ZL1's Avatar
You will be pleasantly surprised!!
2019 COPO #32
350 SC
8.25 167MPH
2018 ZL1-NFG-A10
388CI L8T
9.32 147MPH
Old 01-24-2021, 12:01 PM   #19
sickss228
Got some work done the last couple days. The Cordes ice tank fits like a glove I am very impressed with it. Only minimal modification was necessary to run the 2 lines in and out of the tank. the first 2 pics show the pieces that had to be cut to run them. The template that was supplied with the tank for the vanity plate was also spot on. I traced it cut it and that was it, no additional trimming was needed.
Old 01-24-2021, 12:05 PM   #20
sickss228
Cam, oil pump are in, front cover and oil pan are buttoned up. I also found a diagram for the factory RTV application. I will add pics in case someone needs them
Old 01-24-2021, 12:13 PM   #21
sickss228
A couple fuel system pics. I was on a roll with the aux kit and didnt stop to take many pics. I can say that again Cordes did not disappoint with the fitment and quality of their kit. The only bitch is that the regulator goes in the fender well behind the liner. I'll have to remove the wheel to adjust the fuel pressure when I get it running since the tire is pretty much right up against the gauge. I also cut off the factory check valve line and installed the tube to AN adapter and a Earls -06 check valve.
