#15 |
![]() Drives: 2017 ZL1 Vert M6 Join Date: Feb 2019
Maybe stupid thought - don't you have the standard ZL1 boost gauge in the dash, and can't you compare that reading to your A pillar gauge?
#16 |
Watching that gauge sucks. Much more reliable would be to have HPTuners log some data for you.
2020 ZL1LE A10.
LME LT4 390 short block, LME CID Heads, Kong E2650, FBO. 15" conversion, MT ET Street R 325/15. 100 octane: 1045hp/1055tq. 100 octane + Meth (1x10+): 1117 hp/1067 tq |
#17 |
![]() ![]() ![]() ![]() Drives: 2018 Camaro ZL1 Join Date: Aug 2018
The one on the dash doesn't give you an accurate reading. The OPs gives you an exact number. Not a needle pointing at a line where you have to figure out is it at 8.... mo, it's at 11....no its at 9.
#18 | |
It's the same silly arrangement with the battery gauge on my SS, the range goes from 9 to 19V (why 9V? but much rather, why 19V???) so it's nigh impossible to find out about a low voltage situation
#19 | |
Former GM Technician
Drives: 2018 ZL1 A10, 06 Silverado Duramax Join Date: Sep 2009
Does it read ethanol content as well?
2018 Camaro ZL1 A10
Rotofab Big Gulp, Nick Williams 103, Magnuson 2650, 9.17" (14%) lower, 90mm upper, Vengeance Racing Heads (LME) Cam Package (Cammotion Stage 1), Johnson Lifters, DSX dual intank pump, Lingenfelter high flow check valve, Motion Raceworks Flex Fuel adapter, LPE Big Bore Hpfp, XDI 30% Injectors, BBK shorty headers, Custom 2.75" down pipes, Gesi Gen2 high flow cats, MM catch can. 2006 Silverado Duramax Diesel MPI Compound Turbo 40% over Injectors Efi Live DSP5 Tuning Follow me on Instagram: SwissZL1 |
#20 |
![]() Drives: 18 Tahoe RST, 19 Z06 Join Date: Apr 2017
#21 |
![]() ![]() ![]() ![]() ![]() Drives: 2019 ZL1 Join Date: Mar 2019
The iDash gauge will read a bit nicer and show 0 boost when your actually not in boost and show the proper Boost PSI when your actually in boost. I don't see a need/reason for it to display vacuum on the gauge. To me that would be annoying.
#22 |
IDash.
#23 | |
Drives: '21 Wild Cherry ZL1 Join Date: Aug 2018
Moving to diesels was a weird transition not seeing vacuum. |
#24 |
![]() ![]() ![]() Drives: 2018 ZL1 1LE and 1991 Z28 Join Date: Jan 2009
Those are really nice. I may have to switch them out. Thanks!
In the garage: 2018 HBM ZL1 1LE // 2013 ZL1 (sold) // 1991 Camaro Z28 5.7L // 2022 Audi E-tron SUV (wife's car) // 2002 Camaro SS (sold)
