Old 11-27-2020, 10:13 PM   #15
Jaxcam02
Jaxcam02's Avatar
Drives: 2017 Silverado/2017 ZL1
Hell, second gear for me in some cases rips these tires loose lol
Jaxcam02 is offline   Reply With Quote
Old 11-28-2020, 08:55 AM   #16
craigss50
craigss50's Avatar
Drives: 2017 Camaro SS Fifty
I guess so with that bad boy and 650 HP and TQ.
craigss50 is offline   Reply With Quote
Old 11-28-2020, 09:17 AM   #17
JSH
JSH's Avatar
Drives: '20 ZLE
In 1st, I can ease into the throttle say 50%(can never go WOT at any rpm or speed), in 2nd I can ease into say 75% (can never go WOT at any rpm or speed), in 3rd the car does fine above 30 mph if I ease into WOT, so I guess the slowest roll I can do is in 3rd at 30 or 40mph.
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 11-28-2020, 10:00 AM   #18
Kinda sucks, if you ask me, even my car needs much more careful throttle management now and it's nowhere near your power. No, I'm not bashing your excellent build, it's just a general observation.
Sometimes I wish we had dynamic AWD with a strong RWD bias, only as much torque sent to the front wheels as absolutely necessary to prevent the rear tire roast fest.
Old 11-28-2020, 10:00 AM   #19
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Originally Posted by grampa_ss View Post
No doubt about it....you need to run DRs.
Exactly...When I was bolt-on E85, I could hook from a dig or anywhere even when it was 47 degrees out with DR an pull 3.5s 0-60, 7.7s 0-100...a 305/35/20 555r at that. On street tires it would just blow the tires off below 40 mph.
Even now with the Whipple setup on 10-11psi I can still launch from second gear when its 45-50 degrees out and pull some 3.1 0-60, 6.2 0-100 times.
Old 11-28-2020, 10:23 AM   #20
Altered Carbon
Ghost Spawn
Altered Carbon's Avatar
Drives: Camaro
Bigger, better DRs. I spin too, but good drs make it much less. I'll of course still spin if I just smash it to the floor without easing into it regardless. Unless its a full on a hot big tire slick on a prepped track.
Altered Carbon is offline   Reply With Quote
Old 11-28-2020, 11:30 AM   #21
MackSteelPrivateEye
Originally Posted by 1ssa_camaro View Post
Hey guys, I currently have headers with x pipe, intake, and e85. I ran a single cab Chevy 2014-2018 5.3 with the same bolt ons and e85 tune from a 20 roll. We are tuned by the same shop (New era in socal) He said 20s were a good roll for him. So I gave him his 20 and We ran it and I spun so bad in first and had to play catch up to end up winning him by 2-3 cars. Especially with this cold weather i don’t think I can do a 20-30 roll. Need to be at least a 40. Any similar situations
If you are running a stick you should be doing your 20mph roll from 2nd gear not 1st.
Old 11-29-2020, 07:53 AM   #22
Fred 6528
Fred 6528's Avatar
Drives: 2011 ss
You have to pretend you’re on a gravel road and feather the gas to get it going
Fred 6528 is offline   Reply With Quote
Old 11-29-2020, 10:31 AM   #23
KingLT1
KingLT1's Avatar
In a M6 car 20mph in 1st gear is only 2500 rpm or so. The gearing in M6 cars is really long. A8 is around 3500rpm in 1st gear at 20mph with stock tires.
Old 11-29-2020, 01:42 PM   #24
UnknownJinX
UnknownJinX's Avatar
Drives: 19 Chevrolet Camaro 2SS 1LE Shock
Combined with the torque multiplication effect from the torque converter, it just means it's even easier to break loose in the 1st gear in an A8/A10 than an M6. Even the M6 has trouble gripping as it is when conditions are not perfect.
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock
GM Performance Intake and that's it, because driver mods before car mods
Past:
2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold)
2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled)
UnknownJinX is offline   Reply With Quote
Old 11-29-2020, 02:42 PM   #25
Norm Peterson
corner barstool sitter
Norm Peterson's Avatar
Drives: 08 Mustang GT, 19 WRX
I have this sneaking suspicion that Mr. single-cab picked 20 mph mostly because he knew that was a terrible speed for you to have to start from. Not so much because it might be a good speed for him.
Norm
Old 11-30-2020, 08:07 AM   #26
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
Short of a prepped track on DR and a good burnout is going to hook in 1st, or 2d WOT at ~20mph. Pedal control is paramount. Thinking you can mash it in 1st or 2d is the only thing wrong here. The best street DOT max/ultra summer 305+ isnt going to hook up doing that.
Old 11-30-2020, 09:19 AM   #27
s346k
s346k's Avatar
Drives: like an old lady
idk. i had several instances over the summer where 1st gear dead hooked in my bolt on car with the stock goodyear sc3s. if treated properly, those tires will impress even from a dig on the street. road and ambient temperatures are critical.
Old 11-30-2020, 10:22 AM   #28
WhiteMale
I agree with ya those SC3s can impress in the right situation.
